I have difficulties to the the ML forecast model fit running. The perfect optimisation and the day ahead is doing well. This is the error log:
2024-01-20 09:31:46,605 - web_server - INFO - EMHASS server online, serving index.html…
2024-01-20 09:31:49,485 - web_server - INFO - Setting up needed data
2024-01-20 09:31:49,493 - web_server - INFO - Retrieve hass get data method initiated…
2024-01-20 09:31:49,519 - web_server - ERROR - The retrieved JSON is empty, check that correct day or variable names are passed
2024-01-20 09:31:49,520 - web_server - ERROR - Either the names of the passed variables are not correct or days_to_retrieve is larger than the recorded history of your sensor (check your recorder settings)
2024-01-20 09:31:49,521 - web_server - ERROR - Exception on /action/forecast-model-fit [POST]
File “/usr/local/lib/python3.11/dist-packages/flask/app.py”, line 1455, in wsgi_app
response = self.full_dispatch_request()
File “/usr/local/lib/python3.11/dist-packages/flask/app.py”, line 869, in full_dispatch_request
rv = self.handle_user_exception(e)
File “/usr/local/lib/python3.11/dist-packages/flask/app.py”, line 867, in full_dispatch_request
rv = self.dispatch_request()
File “/usr/local/lib/python3.11/dist-packages/flask/app.py”, line 852, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File “/usr/local/lib/python3.11/dist-packages/emhass/web_server.py”, line 181, in action_call
input_data_dict = set_input_data_dict(config_path, str(data_path), costfun,
File “/usr/local/lib/python3.11/dist-packages/emhass/command_line.py”, line 146, in set_input_data_dict
rh.get_data(days_list, var_list)
File “/usr/local/lib/python3.11/dist-packages/emhass/retrieve_hass.py”, line 150, in get_data
self.df_final = pd.concat([self.df_final, df_day], axis=0)
UnboundLocalError: cannot access local variable ‘df_day’ where it is not associated with a value
any ideas? as mentioned the linear optimisation works, bus the ML optimisation doesn’t.
thanks for any help.
