hi… i have setup the Emoncms history integration, but data do not reach emoncms and i get an error in the log that does ot say or hint me enough as to what is wrong
the url is a vpn ip but when i enter it in browser it do work, i use tailscale vpn and i have also intalled the integration for that and HA do show up in my admin console at tailscale
the error is:
2023-06-22 15:41:29.109 ERROR (SyncWorker_8) [homeassistant.components.emoncms_history] Error saving data ‘{sensor.control_dhw_domestichotwatertanktemperature:54.5}’ to ‘100.126.215.89:8081/emoncms/input/post.json’
i wonder if the integration is used by anyone since i have reached out a lot but no luck so far
i cant ping out from the HA raspberry pi
[core-ssh ~]$ ping 100.126.215.89
PING 100.126.215.89 (100.126.215.89): 56 data bytes
^C
— 100.126.215.89 ping statistics —
26 packets transmitted, 0 packets received, 100% packet loss
[core-ssh ~]$ ping dmi.dk
PING dmi.dk (130.226.165.166): 56 data bytes
^C
— dmi.dk ping statistics —
8 packets transmitted, 0 packets received, 100% packet loss
[core-ssh ~]$
not to the tailscale vpn ip but not the danish weather service either
the raspberry pi is based on the pi image if that is still out there
so both integration and add-on is useless in my case ?
ie to create an outgoing connection from the HA machine
i know how to install it on a normal raspberry pi, just not how to do on a HA pi… it has way more than 2 partitions to start with and the login prompt is also different
What you cant do (at the moment) is use the addon as a gateway to your network for other network devices. Only home assistant and its connected devices.
