Can the Emporia smart plugs, like these on amazon (Amazon.com) be added to the Energy Dashboard? When I search Emporia, all I got were posts related to the Vue. Thanks.
Hi @modernhistorian where you able to get the smart plugs integrated into HomeAssistant? I got the same plugs, and should have done the research before ordering them. (new to home assistant), so newb mistake. thanks
The Vue integration includes the smart plugs. Add it with HACS using this repository
https://github.com/magico13/ha-emporia-vue
The smart plugs integrate well into the energy dashboard. Use an integration sensor, like so:
- platform: integration
source: sensor.refrigerator_power
name: "Refrigerator Energy Total"
unique_id: refrigerator_energy_total
unit_prefix: k
round: 2
The source for this sensor is the emporia one minute sensor, which I renamed as sensor.refrigerator_power. Then on settings>dashboards>energy use the integration sensor as the source for individual devices monitoring. I have eight of these; the only drawback is that the VUE integration does require internet. For whole house and solar monitoring I use the shelly EM3, which does not.
I have found the people here to be very helpful. One tip I would give is to use include files in your configuration.yaml; otherwise, it grows to be unwieldy. Like so:
script: !include scripts.yaml
scene: !include scenes.yaml
switch: !include switches.yaml
template: !include templates.yaml
sensor: !include sensors.yaml
#device_tracker: !include device_trackers.yaml
mqtt: !include mqtt.yaml
#utility_meter: !include utility_meters.yaml
light: !include lights.yaml
