Hi!
I’ve just disabled the yr symbol sensor, and restarted HassIO. I still have two circle in my heading.
How do I get rid of them?
Cheers,
Alex
Hi!
Cheers,
Alex
code? screen shot? …anything?
No, just another crystal ball believer.
The yr
sensor is enabled by default, and shows some weather information. I tried some config options. I finally disabled the sensor for good as shown below:
# Weather prediction
# - platform: yr
# name: Wetter
# forecast: 24
# monitored_conditions:
# - temperature
This is how one of them looked before I disabled it:
However, the placeholders in the top bar are still there. It was blue circle having the caption “not found”.
Since Lovelace promotes itself as “it does everything automatically”, I expect it to automatically remove such placeholders if I disabled the respective sensor.
Did you restart HA after you made the change? I assume so but I’m having some weird things occurring with lovelace myself and need to restart HA when making a frontend configuration change before the change is actually picked up.
Yes, I did. That removed some icons.
I finally managed to remove them by using the “Raw Edit Config” option of Lovelace UI.
