Empty Logbook and History
Logbook and History are empty and also there is no history graphs anymore. I can see the values from sensors and also switches work.
I tried to remove home-assistant_v2.db but it does not help.
Does anyone know what is going on in my case?
Thanks in advance!
Hi @roktheroger, do you have recorder enabeled in your config?
Yes, recorder is enabled.
I found out that sometimes everything works fine but every once in a while I have problems with history and logbook although I did not do any changes in configuration file.
Maybe you’ll find something in the log when you enable debug for the recorder.
logger:
  default: warn
  logs:
    homeassistant.components.recorder: debug
Thank you for your help. I enabled debug for recorder and than I need to wait, that the error will be present again.
I already see some error messages but I think they are not related whit history problem.
I will report if I find something!
Thanks again!
Unfortunately I didn’t manage to solve my problem with history but now I know, that the problem occurs after each change of code. Then it takes a few minutes and everything works fine again.
There is also no useful information in home-assistant.log
