2023-09-15 00:45:40.989 WARNING (MainThread) [homeassistant.components.rest.util] Empty reply found when expecting JSON data
2023-09-15 00:46:10.942 WARNING (MainThread) [homeassistant.components.rest.util] Empty reply found when expecting JSON data
2023-09-15 00:46:40.989 WARNING (MainThread) [homeassistant.components.rest.util] Empty reply found when expecting JSON data
2023-09-15 00:47:11.005 WARNING (MainThread) [homeassistant.components.rest.util] Empty reply found when expecting JSON data
2023-09-15 00:47:40.989 WARNING (MainThread) [homeassistant.components.rest.util] Empty reply found when expecting JSON data
But even with
homeassistant.components.rest.util: debug
I only get the lines above and no details about which call or context brings it.
I assume I know which is the relevant REST call, but is there no option to see more context/proof?
And if it the call I have in mind how to avoid the warnings in the rest sensor? Most probably they appear when the REST endpoint is not available. But I would like to skip this warnings in that case and I would think that another warning (endpoint not reachable) would be even more important than an “empty” JSON.
Just to be sure: you know that you can add a Log filter to exclude specific logs at specific levels?
For instance like this:
# Setting the logging level
# The logging level can temporarily be changed for components via the service: logger.set_level
logger:
default: warn
logs:
homeassistant.components.rest.util: error
No. Neither to get any more detailed error/waring log which is leading to the right underlying entity/config nor to define for specific REST interfaces, that an unreachable is o.k. and should not be responded with an error/warning.
so I was able to get to the bottom of this by turning httpx logger up to debug and then I could see the path and host of the failing request and track it back to the integration at fault… I did bump the rest logger a bit too, but it wasnt really all that helpful and settled on httpx: debug.
