I recently migrated from an RPi3 to RPi4 and all looks good except I have a couple of errors in the log that I cannot work out the reason for them.
The errors are:
[homeassistant.components.emulated_hue.hue_api] Entity not exposed: 3
[homeassistant.components.emulated_hue.hue_api] Entity not exposed: 16
Its the 3 and 16 that I’m scratching my head over since I cannot find what they may relate to. I have tried a number of times forgetting all devices in the Alexa app and rediscovering them but to no avail.
Has anyone any suggestions please as to what the numbers 3 and 16 may point to?
I found the problem after realising that the numbers relate to the entity numbers in the emulated_hue_ids.json file. I had completely forgotten about this file from working with it long ago. Thought I would mention it in case someone else happened to have the same issue.
I hope it’s ok to resurrect this thread… I have the same issue, but can’t find the emulated_hue_ids.json file.
I set up a new SD-Card wir HAOS and restored an older backup. From that backup, I see 2 renamed emulated_hue_ids.json files which I once kept as backup (adding .bak / .bak2 to the name) - so it seems I’m looking at the right place
Do I need to do something manual to trigger creation of the ids file after restoring a backup?
I think you will find the file now is renamed to emulated_hue.ids and is located in the config.storage folder. At least that is how it is with mine now.
