Emulated Hue with delay
Hi all,
today I configured all my Hue Lamps via Emulated Hue (Home Assistant Core Docker running on Unraid Server), it works but often with higher delay. Sometimes it takes 2 seconds, sometimes up to 6 seconds. Is there a reason why the delay via Emulated Hue is present?
Here my configuration:
emulated_hue:
  host_ip: 192.168.0.4
  listen_port: 80
  upnp_bind_multicast: true
  expose_by_default: false
Thank you,
Lukas
@luk1 - Did you found a solution for this delay ? I noticed the same when trying to integrate one RGB light with my Philips TV and the ambient was not in sync with the bulb.
