Anyone successfully running the latest Echo Dot v3 with emulated Hue?
I’ve read reports that only older devices are supported. Would be great if anyone could confirm.
Thanks in advance.
Thanks in advance.
You should believe what you read, you can use newer gen Echos with it as long as you have a gen 2 Dot or older attached to your network.
