emulated_hue
As documentation says, with port 80 works fine. H
Any ideas?
emulated_hue
Any ideas?
what are your settings for nginx?
I have the same problem.
I use port 80 with nginx and I can´t run emulated hue in the same port.
I just setup nginx and am also already using emulated hue. I am running HA in docker and my solution was to use docker to direct a port 8080 to nginx 80 port and the port forward in the router outisde port 80 to docker port 8080.
