When a Shelly 2.5 is controlling roller shutters, there exists the ability to set the “Input buttons” mode of the Shelly. This allows for the possibility of the shutters to be controlled with two separate buttons – one for up, one for down-- OR one button. In the case of “one button” mode, every time the button is pressed, the roller will go in the next sequence step. For example, a button press would start the opening the roller, the next would stop the rolling, the next would start closing the roller, the next press would stop it, etc.
As I have two physical buttons to control my roller, I wanted to use both buttons to control the roller however I wanted to emulate this one button mode using Home Assistant. With the Shelly integrated as a cover, this was relatively straightforward: I needed to keep track of the last state of the roller and either open the roller, close the roller, or stop the roller based on the last state of the roller.
To do this, I created one automation with an action to store the cover's last state in an input_select (an input_text would have worked as well) that was triggered every time there was a state_changed event for the cover. I then created a second automation that, when triggered, would either call cover.open_cover, cover.close_cover, or cover.stop_cover depending on the last state of the cover which is stored in the input_select as an option/value.
Here are the two automations:
alias: Set Bedroom Shutter State (Event Trigger)
description: ''
- platform: event
event_type: state_changed
condition:
- condition: template
value_template: '{{ trigger.event.data.entity_id == "cover.bedroom_shutters" }}'
- service: input_select.select_option
option: '{{ trigger.event.data.old_state.state }}'
entity_id: input_select.bedroom_shutter_last_state
mode: single
alias: Toggle Bedroom Shutters
description: ''
- device_id: 6124f02a20f611eb8f2d55764adf7b07
domain: zha
platform: device
type: remote_button_alt_short_press
subtype: button_2
condition: []
- choose:
- conditions:
- condition: state
state: closing
sequence:
- service: cover.open_cover
entity_id: cover.bedroom_shutters
- conditions:
- condition: state
state: opening
sequence:
- service: cover.close_cover
default:
- service: cover.stop_cover
mode: single
