Hello, I am trying to install the conversation integration but it is not listed when I search in the integrations.
I am using the latest HA
And my configuration.yaml is:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 5
# Example configuration.yaml entry
alarm_control_panel: !include alarm_control_panel.yaml
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
homeassistant:
allowlist_external_dirs:
- "/config"
- platform: systemmonitor
resources:
- type: processor_use
- type: disk_use_percent
arg: "/"
- type: disk_free
arg: "/"
- type: memory_use_percent
- type: network_in
arg: eth0
- type: throughput_network_in
arg: eth0
- type: network_out
arg: eth0
- type: throughput_network_out
arg: eth0
- type: processor_temperature
- type: last_boot
- platform: command_line
scan_interval: 60
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(2) }}'
- platform: filesize
scan_interval: 1800
file_paths:
- /config/home-assistant_v2.db
Any assistance is appreciated
Thank you
