I cannot seem to figure out how to connect my camera stream from blue iris to Hassio. Connecting the camere stream separate is not a problem but connecting it via BI does not seem to work with Mjpeg and still image!
What version of blue Iris are you running? If you are using ui3 vs ui2 the auth changed so the easiest way to enable it in ha is to disable authentication for local network in blue Iris.
I am using the exact same URL but it still won’t work, when I open the URL directly within my browser I am getting a constant stream after login on BI.
