Enable/disable automation alarm
I wish to create a button or switch on my dashboard, to enable/disable an automation who is an active an “alarm mode”.
My automation send me notification if my cameras detect movement or if my windows detector receives open state.
alias: Alarm
description: Alarme
  - platform: device
    device_id: 149b2799b5d82a300c5601165b9a2ce3
    domain: select
    entity_id: ce1d019c9d7a9853ebc8a197baf214c8
    type: current_option_changed
    to: Motion Record
  - platform: device
    type: changed_states
    device_id: 6f103c1b1a43d909ba4d1b7ac02c5915
    entity_id: c348971f284a1488f429242ac2e4eb4b
    domain: switch
  - type: opened
    platform: device
    device_id: db00d9e1535e6533dade812e8e0e2bc1
    entity_id: d13149d5c0a13d70ff1b34d07bc1c38d
    domain: binary_sensor
condition: []
  - choose:
      - conditions:
          - condition: device
            domain: select
            type: selected_option
            option: Motion Record
        sequence:
          - service: telegram_bot.send_message
            metadata: {}
              message: Un mouvement a été détecté sur la caméra intérieure.
              title: Alerte mouvement intérieur!
      - conditions:
          - condition: device
            type: is_on
            domain: switch
        sequence:
            metadata: {}
              message: Un mouvement a été détecté dehors.
              title: Alerte mouvement extérieur!
      - conditions:
          - type: is_open
            condition: device
        sequence:
            metadata: {}
              message: La baie vitrée a été ouverte.
              title: Alerte baie vitrée ouverte!
mode: single
Maybe something better is also possible.
Thanks.
service: automation.turn_off
  entity_id: automation.your_automation
  stop_actions: true
There is also the corresponding turn_on and toggle
I use the alert platform. It has better flexibility.
Here’s an example
This has an input boolean to enable / disable the alert. It also only fires if the house is alarmed.
input_boolean:
  al_dr_man_door_alert_enable:
    name: dr_man_door alert enable
binary_sensor:
    sensors:
      al_dr_man_door_alert:
        value_template: '{{ (is_state("binary_sensor.man_door_open","on") and is_state("binary_sensor.aw_alarm_enable","on")) and is_state("input_boolean.al_dr_man_door_alert_enable", "on") }}'
alert:
  al_dr_man_door:
    message: 'ALERT {{state_attr("zone.home","friendly_name")}} dr_man_door door opened'
    done_message: 'Cleared {{state_attr("zone.home","friendly_name")}} dr_man_door door opened'
    entity_id: binary_sensor.al_dr_man_door_alert
    state: "on"
    repeat:
      - 60
      - 240
    can_acknowledge: true
    skip_first: false
    notifiers:
      - sms_telegram_admin
recorder:
Thanks for yours answers.
Don’t know where to put code.
My button card is like:
show_name: true
show_icon: true
type: button
tap_action:
  action: toggle
entity:
Where and how to put :
  stop_actions: true
Or
input_boolean:
binary_sensor:
    sensors:
alert:
  al_dr_man_door:
    state: "on"
    repeat:
      - 60
      - 240
    skip_first: false
    notifiers:
recorder:
Or
  - platform: state
    entity_id:
      - binary_sensor.yard_motion_sensor
    to: "on"
condition:
  - condition: state
    entity_id: input_boolean.yard_override
    state: "off"
  - service: light.turn_on
      entity_id: light.yard
Don’t turn automations on and off, use a condition instead.
Create a Toggle (input_boolean) helper called Alarm Override. Put that in a dashboard so it appears as a switch.
Then add it to your automation. If you are working in YAML, replace the:
condition: []
with
condition:
  - condition: state
    entity_id: input_boolean.alarm_override
    state: "off"
If you are working in the UI, add a condition (“And If” in the English version) like this but with your alarm_override helper:
I’m adding the slider :
type: custom:slider-button-card
entity: input_boolean.alarm_override
slider:
  direction: left-right
  background: gradient
  use_state_color: true
  use_percentage_bg_opacity: false
  show_track: false
  toggle_on_click: true
  force_square: false
  show_attribute: false
show_name: true
show_state: true
compact: false
icon:
  show: true
  tap_action:
    action: more-info
action_button:
  mode: toggle
  icon: mdi:power
  show: true
  show_spinner: true
  tap_action:
    action: toggle
And my automations
alias: Alarm
description: Alarme
  - platform: device
    domain: select
    to: Motion Record
  - platform: device
    domain: switch
  - type: opened
    platform: device
condition:
  - condition: state
    state: "off"
  - choose:
      - conditions:
          - condition: device
            domain: select
        sequence:
            metadata: {}
      - conditions:
          - condition: device
            type: is_on
            domain: switch
        sequence:
            metadata: {}
      - conditions:
          - type: is_open
            condition: device
        sequence:
            metadata: {}
mode: single
But slider is on or off, I’m always receiving notifications.
Then either your card is not changing the slider properly, or you’ve not re-loaded the automations. If that input boolean is on, the action block will not be reached when the automation is triggered.
If you run the automation manually (rather than by a trigger) then only the action section is executed. That is expected behaviour.
Is it always better to use a condition instead of disabling an Automation? So for example of you have a summer and winter automation check on summer/ winter to determine which should run?
There might be edge cases, but I would do it that way, yes. It’s more elegant and less confusing.
Thanks :slight_smile:
Here my button code :
slider:
  show_track: false
  force_square: false
show_name: true
show_state: true
compact: false
icon:
  show: true
  tap_action:
    action: more-info
action_button:
  mode: toggle
  icon: mdi:power
  show: true
  show_spinner: true
  tap_action:
    action: toggle
And my alarm automation :
alias: Alarm
description: Alarme
  - platform: device
    domain: select
    to: Motion Record
  - platform: device
    type: turned_on
    entity_id: d7da3ff4c10714c4dd42650161ff93d2
    domain: switch
  - type: opened
    platform: device
condition:
  - condition: state
    state: "on"
  - choose:
      - conditions:
          - condition: device
            domain: select
        sequence:
            metadata: {}
      - conditions:
          - condition: device
            type: is_on
            domain: switch
        sequence:
            metadata: {}
              photo:
                file: >-
                  /api/camera_proxy/camera.r4252_smart_outdoor_camera?token=93d768ac5b2bdbe75d3754e1267043cddabff79db77a93f97eb9036c4b6b0149
                caption: Photo
      - conditions:
          - type: is_open
            condition: device
        sequence:
            metadata: {}
mode: single
Now, need to test if the three trigger work well (when motion is detected on camera 1, or when motion is detected on camera 2, or when window is open).
And after that, to succeed install and configure frigate to capture camera picture and send to telegram.
Thanks.
Just a thought, know this conversation is old, but doesn’t it reduce overhead on the system if you disable the automation. For example, if you are away and you have your alarm on you want to check on any motion. If you leave that automation on all the time it requires the system to check every time there is motion in the house when the alarm isn’t on. Even if it is a quick check, still seems like a lot of overhead that isn’t needed.
Yes it would reduce the overhead. Is it enough to make a difference - probably not.
I/O (comms to devices) is slow (meaning 10-100ms) and too much can overwhelm some device networks (zwave, zigbee,…). And hence care and optimization are important and necessary.
Automations are quick on modern processors. You’re really talking about microseconds to trigger and test a condition. Even if the motion sensor trigger once a minute, it’s an additional 1440 microseconds of work a day which is 0.0014 seconds. So that’s not going to be noticeable even if you have 100 motion sensors. In contrast if those 100 motion sensors are zwave and are firing once a minute that may seriously impact the zwave network and cause delays turning lights on, etc.
Thanks for the response. When I first started programming (assembly language real time systems, wont say how many years) every ms counted. I guess I still carry that around with me. :slight_smile:
