Hi there!
how can i enable/disable the lock option of a button-card using the state of a certain sensor?
This is my code
Thanks in advance
Hi there!
This is my code
Thanks in advance
Use this:
If you have issues or questions post them in that topic.
Thanks tom for the answer. I have this card that i want to lock/unlock based on the state of an input_boolean entity.
- card:
entity: switch.sprinkler_relay_1
row: true
type: 'custom:restriction-card'
restrictions:
block: true
condition:
value: 'on'
entity: group.sprinkler_running_status
i found this example:
entities:
- card:
row: true
restrictions:
block: true
condition:
value: 'on'
but i cannot match both codes. Any idea?
