Enable/disable RESTful blocks of code in a configuration.yaml
In my configuration.yaml fill I have two blocks of RESTful code that I use to access cloud based information about my PV system. The cloud seems to get overwhelmed and when additional RESTful sensors it tends to become unresponsive. Is there a way that I could selectively enable/disable the individual blocks of RESTful code so that their execution could be staggered? Maybe even set a flag to indicate when one block of code has successfully received a response back so that the next block can be executed?
#CONFIGURATION.YAML yaml file
# Loads default set of integrations. Do not remove.
default_config:
# Line to enable HA Configuration Editor
config_editor:
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
# RESTful INTEGRATIONS
rest:
# Studer Synoptic Data Request
  - authentication: basic
    method: GET
    scan_interval: 10
    timeout: 120
    resource: https://api.studer-innotec.com/api/v1/installation/synoptic/NNNN #replace NNNN with your Studer system ID
    headers:
      Accept: application/json
      UHASH: !secret UHASH  # Points to SHA256 encoded username in secrecs.yaml file, or you can replace !secret UHASH with your hard coded SHA256 encoded username right here in the configuration.yaml file
      PHASH: !secret PHASH  # Points to #MD5 encoded password in secrecs.yaml file, or you can replace !secret UHASH with your hard coded #MD5 encoded password right here in the configuration.yaml file
      - name: "Studer"
        unique_id: "studer"
        value_template: "42"
        json_attributes:
          - energy
          - battery
          - power
# Studer Aux contact status read
    method: GET
    scan_interval: 30
    timeout: 120
#Put you Studer cloud credentials and system ID in the line below.
    resource: "https://portal.studer-innotec.com/scomwebservice.asmx/ReadUserInfo?email=<[email protected]>>&pwd=<your_studer_password>&installationNumber=<your_studer_system_ID>&device=XT1&infoId=3031"
      - name: "Studer Xtender AUX1"
        unique_id: "studer_xtender_aux1"
        value_template: "{{ 'unavailable' if (value_json.UserInfoResult.ErrorCode!='1') else 'opened' if (value_json.UserInfoResult.UIntValue=='0') else 'closed' }}"
        json_attributes_path: "$['UserInfoResult']"
        json_attributes:
          - UIntValue
          - FloatValue
          - ErrorCode
          - ErrorMessage
          - ScomFormatNo
# TEMPLATE INTEGRATION
template:
#sensor to identify if daylight savings for selecting summer or winter tariff structure
  - binary_sensor:
      - name: "Is DST"
        state: "{{ now().timetuple().tm_isdst == true }}"
#INCLUDE for tariffs sensor calculations
  - sensor: !include tariffs.yaml
#INCLUDE for Studer sensors that copy data from RESTful API call attributes
  - sensor: !include studer.yaml
#INCLUDE for Shelly sensor calculations
  - sensor: !include shelly.yaml
#INCLUDE for Tuya sensor yaml blocks
  - sensor: !include tuya.yaml
I was using a very long update time and calling update entity service for respective rest sensor through automations whenever i want, so i can control the order and load on server end
As fuatakgun said, extend the scan interval out to several years or more, and then use an automation to trigger updates with the update_entity service.
Then in an automation have an action something like:
service: homeassistant.update_entity
data: {}
  entity_id: sensor.studer
Yes this is right :slight_smile:
I put together an automation that alternately calls 2 RESTful blocks. The first block is called once, then the second is called 5 times in a row based on the value of a counter. The blocks are called every 5 seconds unless the cloud responded with an error on the last read, then the call rate is reduced to one a minute.
I imagine there is a ore elegant way of doing this, but it hasn’t occurred to me.
What happens if the RESTful block is called before it has received data from the previous request?
alias: Studer RESTful API call
description: ""
  - platform: time_pattern
    seconds: /5
    minutes: /1
condition: []
  - if:
      - condition: state
        entity_id: sensor.studer_cloud_status
        state: Studer Cloud Online
      - condition: state
        entity_id: sensor.studer_aux1_api_read_status
        state: AUX Read OK
        enabled: true
    then:
      - if:
          - condition: trigger
            id:
              - scan
        then:
          - choose:
              - conditions:
                  - condition: numeric_state
                    entity_id: counter.studer_restful_scanner
                    below: 1
                sequence:
                  - service: homeassistant.update_entity
                    data: {}
                      entity_id: sensor.studer_xtender_aux1
              - conditions:
                    above: 0
                sequence:
                    data: {}
          - if:
                below: 5
            then:
              - service: counter.increment
                data: {}
            else:
              - service: counter.reset
                data: {}
    else:
      - if:
            id:
              - retry_after_pause
        then:
          - choose:
              - conditions:
                    below: 1
                sequence:
                    data: {}
              - conditions:
                    above: 0
                sequence:
                    data: {}
          - if:
                below: 5
            then:
                data: {}
            else:
                data: {}
mode: single
I have been unable to get update_entity to refresh a rest sensor more than once every 10 seconds. It seems to be throttled.
Does anyone know if this is intended - AFAICS it is not documented anywhere.
What if you want to refresh up to 1/sec? update_entity does not seem to allow this…
