Right now every time I restart home-assistant I need to turn on the Flux switch, is there any way to have it on by default?
By automation.
automations:
- action:
- data:
entity_id: switch.flux
service: switch.turn_on
alias: enable flux on platform start
- event: start
platform: homeassistant
Flux should use an entity names switch.flux, you better check and adjust this if required.
Thanks! I’ll try this
Tried this and can confirm that it works. Thanks!
