I set up HA so that I can access it both via https://xxx.duckdns.org (with port forwarding 443 to 8123) and, being in the same LAN, via https://192.168.y.y:8123 (by ignoring the SSL error).
I cannot access to http://192.168.y.y:8123 (no SSL) because HA doesn’t accept HTTP requests.
Can I enable them, since a remote access must use port 443 (so it must be HTTPS)?
My DuckDNS configuration:
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
token: ***
domains:
- xxx.duckdns.org
aliases: []
seconds: 300
My configuration.yaml:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: ...
login_attempts_threshold: ...
