How to configure SSH port.
I look in HA network but i can’t setup ssh port
I install addon ssh terminal and it has nothing inside configuration
I enter VM run ha help, and i can’t see anything about ssh.
How can i enable it?
You can connect to the HASS container running inside HASSOS from the local LAN pretty much as standard. As there are the additional layers of container and supervisor, I doubt if there is a way to alter the port mappings in HASSOS, but it may be possible if you decide to run your own container host (I don’t).
With the web console add-in, you can also SSH and SCP out from HASS to the LAN - which is handy to transfer backups to another maching.
$ ssh [email protected]
| | | | /\ (_) | | | |
| |__| | ___ _ __ ___ ___ / \ ___ ___ _ ___| |_ __ _ _ __ | |_
| __ |/ _ \| '_ \ _ \ / _ \ / /\ \ / __/ __| / __| __/ _\ | '_ \| __|
| | | | (_) | | | | | | __/ / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_| |_|\___/|_| |_| |_|\___| /_/ \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
