Enable the option to include a script in a package
Using packages has some advantages, especially if you like the yaml way of living.
You can include almost everything in a package like groups, template definition, integrations and automations. This enebles me to create one package for a project, like my garden irrigation system or alarm. However, I simply cannot include a script in a package, simply because the dict definitions are missing…
Can you clarify what you are talking about and/or share an example that isn’t working?
I created some notification scripts, and put them in the package directory. The I get the error that it was not able to merge, because there is no dict. As I read the documentation page about packages, scripts indeed are not mentioned…
example script for in the package:
notification_package_script:
# PDW 2023-08, V1
  script:
  - id: F968B7BA929F417BAFA431A50C047EB0
    alias: notify_sender
    description: send message urgent to all devices using push and telegram and persistant
    icon: mdi:message-text-fast-outline
    fields:
      topic:
        description: "short title identifying the tread"
        example: "Alarm"
      message:
        description: "The actual message to send"
        example: "Motion detected in Home(assistant)"
      snapshot:
        description: "filename of a snapshot to be sent"
        example: '{{state_attr("var.camera_driveway","last_snapshot_alarm")}}'
    variable:
      image_url: >-
        {%- if snapshot != "" -%}
          https://home.myserver.online/local/snapshots/{{snapshot}}
        {%- else -%}{{""}}{%- endif -%}
      image_md: >-
         ´![Foto]({{image_url}})'
    sequence:
    # Persistant notification
    - service: persistent_notification.create
        title: '{{topic}}'
        message: '{{message }}  {{image_md}}'
    # Push notification to the app
    - service: notify.all_devices
        message: '{{topic}}/n{{message}}'
          url: '{{image_url}}'
          clickAction: '{{image_url}}'
          channel: Motion
          importance: high
          push:
            interruption-level: time-sensitive
          ttl: 0
          priority: high
    # Send message to Telegram
    - service: notify.telegram
        title: '{{topic}}'
        message: '{{message }}'
          photo:
          - url: '{{image_url}}'
You need to include a key/object_id for each script entity, just like you would in the standard scripts.yaml file.
# PDW 2023-08, V1
  script:
    notify_sender:
      description: send message as defined in var.notification_message
      fields:
        topic:
          example: "Alarm"
        message:
        snapshot:
      variables:
        image_url: >-
            https://home.goatnet.nl/local/snapshots/{{snapshot}}
        image_md: >-
      sequence:
        # Persistent notification
            title: '{{topic}}'
              channel: Motion
              importance: high
              push:
              ttl: 0
              priority: high
            title: '{{topic}}'
              photo:
Thanks!
You are right, despite it is not explicitly mentioned in the documentation, it is actually possible this way!
I’m having a similar issue - I tried to include a script within a package to test it out:
homeassistant:
  customize:
    package.node_anchors:
      living_room_illuminence: &illuminance "{{ states('sensor.living_room_sensor_illuminance')|float }}"
script:
  this_is_a_test_script:
    description: "This is a test script in a package"
    mode: queued
    fields:
      YES_OR_NO:
        description: "Yes o no boolean"
        example: "T,t,true,yes,Yes,Y,ON,on,On"
    sequence:
      - service: system_log.write
          message: >
            {% set data = namespace(print_out="SCRIPT Test: " + YES_OR_NO) %}
            {{ data.print_out }}
          logger: SCRIPT-PACK-TEST
          level: error
The package is included via the following statement in my config file:
homeassistant:
  packages: !include_dir_named config-include-files/packages/
The error is:
Setup of package 'xxx' at config-include-files/packages/xxx.yaml, line 16 failed: integration 'script' cannot be merged, dict expected in main config
I’m sure I’m missing something but I can’t think of any other variations to try.
