Hello there! I am a total newbie for ESPHome.
Problem
I am trying to log "hello world" to my dev board via the command line option esphome run hello.yaml, but I have been unsuccessful.
Versions and board
- macOS Monterey 12.6
- Python: 3.10.6
- pip3 version: 22.2.2
- esphome version: 2022.8.3
- ESP32-S3-DevKitC-1-N8R2, the official dev board from Espressif
- Arduino ESP32 package install 2.0.4
What works
I successfully uploaded a simple hello world to the board ESP32-S3-DevKitC-1 via the Arduino IDE with ESP32 Arduino 2.0.4.
I have also successfully compiled and uploaded to the board the following complete YAML file:
esphome:
esp32:
board: esp32dev
variant: ESP32S3
framework:
type: arduino
logger:
level: DEBUG
baud_rate: 0
The final terminal output lines are:
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO UART logging is disabled (baud_rate=0). Not starting UART logs.
What does not work
But, when I try to log it gives an error. The YAML file is:
esphome:
on_boot:
then:
- logger.log: "Hello World"
esp32:
board: esp32dev
variant: ESP32S3
framework:
type: arduino
logger:
level: DEBUG
baud_rate: 115200
The final terminal output is:
Leaving...
INFO Starting log output from /dev/cu.usbmodem14101 with baud rate 115200
[17:16:52]Saved PC:0x40378ae8
[17:16:52]SPIWP:0xee
[17:16:52]mode:DIO, clock div:1
[17:16:52]load:0x3fce3808,len:0x43c
[17:16:52]load:0x403c9700,len:0xbec
[17:16:52]load:0x20747261,len:0x26203d3c
[17:16:52]Invalid image block, can't boot.
[17:16:52]ets_main.c 329
[17:16:54]ESP-ROM:esp32s3-20210327
[17:16:54]Build:Mar 27 2021
[17:16:54]rst:0x7 (TG0WDT_SYS_RST),boot:0x28 (SPI_FAST_FLASH_BOOT)
I have also tried tweaking the board details as suggested in another forum thread with the YAML file:
esphome:
on_boot:
then:
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
platform_version: 4.4.0
variant: esp32s3
logger:
level: DEBUG
baud_rate: 115200
HARDWARE: ESP32S3 240MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.40302.0 (4.3.2)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.9.0
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch3
Error: This board doesn't support espidf framework!
====================================== [FAILED] Took 0.58 seconds ======================================
Hunches
I don't know whether esptool is having a problem. Another suspicion on enabling USB CDC on boot, which I had to do when uploading to this board via the Arduino IDE. Either could be completely wrong.
Please help! Thanks!
Just a hunch.
