Enable ZHA for Home Assistant Yellow
I can’t for the life of me get ZHA on my HA Yellow v1.3. I have followed the instructions and googled to no available. I have completely rebuilt the OS and not going to install anything until I get ZHA installed and configured.
I go to Settings > Devices and Services > Add Integration > Zignee Home Automation > /dev/ttyAMA1 - Yellow Zigbee module - Nabu Casa > Submit. It thinks a bit, makes me select the Radio Type and I select EZSP (I have tried them all) > Port Speed = 115200, Data flow control = bottom radial (but i have selected them all). Get the error Failed to connect
HomeAssistant Core Errors
Logger: py.warnings
Source: /usr/local/lib/python3.12/warnings.py:112
First occurred: 8:00:31 PM (5 occurrences)
Last logged: 8:00:31 PM
/usr/local/lib/python3.12/site-packages/gpiozero/devices.py:288: PinFactoryFallback: Falling back from rpigpio: No module named 'RPi' warnings.warn(
/usr/local/lib/python3.12/site-packages/gpiozero/devices.py:288: PinFactoryFallback: Falling back from lgpio: No module named 'lgpio' warnings.warn(
/usr/local/lib/python3.12/site-packages/gpiozero/devices.py:288: PinFactoryFallback: Falling back from rpio: No module named 'RPIO' warnings.warn(
/usr/local/lib/python3.12/site-packages/gpiozero/devices.py:288: PinFactoryFallback: Falling back from pigpio: failed to connect to localhost:8888 warnings.warn(
/usr/local/lib/python3.12/site-packages/gpiozero/devices.py:285: NativePinFactoryFallback: Falling back to the experimental pin factory NativeFactory because no other pin factory could be loaded. For best results, install RPi.GPIO or pigpio. See https://gpiozero.readthedocs.io/en/stable/api_pins.html for more information. warnings.warn(NativePinFactoryFallback(native_fallback_message))
Installed the Silicon Labs Flasher with the same settings.
 Home Assistant Core: 2024.8.3
 Home Assistant Supervisor: 2024.08.0
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[20:53:02] INFO: Detected Home Assistant Yellow
[20:53:02] INFO: Starting universal-silabs-flasher with /dev/ttyAMA1 (bootloader baudrate 115200)
2024-09-03 20:53:04.022 core-silabs-flasher asyncio DEBUG Using selector: EpollSelector
2024-09-03 20:53:04.026 core-silabs-flasher universal_silabs_flasher.flash INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=1, sdk_version='4.4.3', ezsp_version='7.4.3.0', ot_rcp_version=None, cpc_version=None, fw_type=<FirmwareImageType.NCP_UART_HW: 'ncp-uart-hw'>, baudrate=115200)
2024-09-03 20:53:04.026 core-silabs-flasher universal_silabs_flasher.flash DEBUG Probing app type ApplicationType.EZSP first
2024-09-03 20:53:04.027 core-silabs-flasher universal_silabs_flasher.flash DEBUG Probing with 115200 baudrate first
2024-09-03 20:53:04.027 core-silabs-flasher universal_silabs_flasher.flasher INFO Triggering yellow bootloader
2024-09-03 20:53:04.330 core-silabs-flasher universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-09-03 20:53:04.331 core-silabs-flasher zigpy.serial DEBUG Opening a serial connection to '/dev/ttyAMA1' (baudrate=115200, xonxoff=False, rtscts=False)
2024-09-03 20:53:04.333 core-silabs-flasher universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.gecko_bootloader.GeckoBootloaderProtocol object at 0x7fb46cf210>, Serial<id=0x7fb46b1d20, open=True>(port='/dev/ttyAMA1', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-09-03 20:53:04.335 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\n'
2024-09-03 20:53:04.335 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'3'
2024-09-03 20:53:06.338 core-silabs-flasher universal_silabs_flasher.flasher INFO Probing ApplicationType.EZSP at 115200 baud
2024-09-03 20:53:06.341 core-silabs-flasher zigpy.serial DEBUG Opening a serial connection to '/dev/ttyAMA1' (baudrate=115200, xonxoff=True, rtscts=False)
2024-09-03 20:53:06.344 core-silabs-flasher bellows.ezsp DEBUG Resetting EZSP
2024-09-03 20:53:06.344 core-silabs-flasher bellows.uart DEBUG Resetting ASH
2024-09-03 20:53:06.345 core-silabs-flasher bellows.ash DEBUG Sending frame CANCEL + RstFrame() + FLAG
2024-09-03 20:53:06.345 core-silabs-flasher bellows.ash DEBUG Sending data  1ac038bc7e
2024-09-03 20:53:11.351 core-silabs-flasher universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 460800 baud
2024-09-03 20:53:11.352 core-silabs-flasher zigpy.serial DEBUG Opening a serial connection to '/dev/ttyAMA1' (baudrate=460800, xonxoff=False, rtscts=False)
2024-09-03 20:53:11.353 core-silabs-flasher bellows.uart DEBUG Connection lost: None
2024-09-03 20:53:11.354 core-silabs-flasher bellows.uart DEBUG Closed serial connection
2024-09-03 20:53:11.354 core-silabs-flasher universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.cpc.CPCProtocol object at 0x7fb46cf1d0>, Serial<id=0x7fb46b1ae0, open=True>(port='/dev/ttyAMA1', baudrate=460800, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-09-03 20:53:11.355 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:11.358 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:12.360 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-09-03 20:53:12.462 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:12.463 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:13.466 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-09-03 20:53:13.567 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:13.569 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:14.571 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-09-03 20:53:14.672 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:14.674 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:15.677 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-09-03 20:53:15.678 core-silabs-flasher universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 115200 baud
2024-09-03 20:53:15.679 core-silabs-flasher zigpy.serial DEBUG Opening a serial connection to '/dev/ttyAMA1' (baudrate=115200, xonxoff=False, rtscts=False)
2024-09-03 20:53:15.680 core-silabs-flasher universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.cpc.CPCProtocol object at 0x7fb42ebdd0>, Serial<id=0x7fb46b1a80, open=True>(port='/dev/ttyAMA1', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-09-03 20:53:15.681 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:15.683 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:16.685 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-09-03 20:53:16.786 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:16.788 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:17.790 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-09-03 20:53:17.891 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:17.893 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:18.896 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-09-03 20:53:18.997 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:18.998 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:20.001 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-09-03 20:53:20.002 core-silabs-flasher universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 230400 baud
2024-09-03 20:53:20.002 core-silabs-flasher zigpy.serial DEBUG Opening a serial connection to '/dev/ttyAMA1' (baudrate=230400, xonxoff=False, rtscts=False)
2024-09-03 20:53:20.004 core-silabs-flasher universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.cpc.CPCProtocol object at 0x7fb498d890>, Serial<id=0x7fb46b1ab0, open=True>(port='/dev/ttyAMA1', baudrate=230400, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-09-03 20:53:20.004 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:20.006 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:21.008 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-09-03 20:53:21.109 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:21.111 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:22.113 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-09-03 20:53:22.214 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:22.216 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:23.218 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-09-03 20:53:23.320 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-09-03 20:53:23.321 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-09-03 20:53:24.324 core-silabs-flasher universal_silabs_flasher.cpc DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-09-03 20:53:24.325 core-silabs-flasher universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
2024-09-03 20:53:24.325 core-silabs-flasher zigpy.serial DEBUG Opening a serial connection to '/dev/ttyAMA1' (baudrate=460800, xonxoff=False, rtscts=False)
2024-09-03 20:53:24.327 core-silabs-flasher universal_silabs_flasher.common DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.spinel.SpinelProtocol object at 0x7fb42e8250>, Serial<id=0x7fb46b00d0, open=True>(port='/dev/ttyAMA1', baudrate=460800, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2024-09-03 20:53:24.329 core-silabs-flasher universal_silabs_flasher.spinel DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-09-03 20:53:24.330 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-09-03 20:53:25.333 core-silabs-flasher universal_silabs_flasher.spinel DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 1 of 4)
2024-09-03 20:53:25.434 core-silabs-flasher universal_silabs_flasher.spinel DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-09-03 20:53:25.436 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-09-03 20:53:26.438 core-silabs-flasher universal_silabs_flasher.spinel DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 2 of 4)
2024-09-03 20:53:26.539 core-silabs-flasher universal_silabs_flasher.spinel DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-09-03 20:53:26.541 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-09-03 20:53:27.543 core-silabs-flasher universal_silabs_flasher.spinel DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 3 of 4)
2024-09-03 20:53:27.645 core-silabs-flasher universal_silabs_flasher.spinel DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-09-03 20:53:27.646 core-silabs-flasher universal_silabs_flasher.common DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-09-03 20:53:28.649 core-silabs-flasher universal_silabs_flasher.spinel DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 4 of 4)
Error: Failed to probe running application type
[20:53:28] INFO: universal-silabs-flasher-up script exited with code 1
s6-rc: warning: unable to start service universal-silabs-flasher: command exited 1
s6-rc: info: service banner: stopping
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Rebooted the system and I actually saw Yellow Zigbee Home Automation in the discovered integrations. I click Configure and receive an Unknown error occured
Any help would be much appreciated. I enjoy tinkering with things but this has just taken way too much of my time to get one integration implemented.
Your errors do not seem to be related to ZHA, really, but to some GPIO related stuff (custom integration?)
Those are the settings from my working yellow:
I have a small breakthrough. Had some downtime away from the house and found a section in Settings > hardware > configure > switch between Zigbee and Thread Firmware. Clicked zigbee and received “ unsupported_firmware” error. Silicon labs flasher is not working so I may try to manually set the firmware when I get home. Hope this helps anyone in the same situation.
Did you find the solution? I am having the same issue but the past month zigbee has been intermittently dropping off. But now it won’t even configure.
I have been having problems with zigbee on Home assistant yellow too. I had ignored it because I did not have any zigbee devices. but just added a couple of Aqara Roller Shade Driver E1 devices.
I had successfully added them a few days ago, but its been intermittently displaying errors over the past few days as well
I went to grab the error and do some research, but its started functioning again and the blinds are available.
I also just happened to have updated to the latest HA Core 2025.3.4/ Supervisor 2025.03.4
I wonder if it was fixed in that update, or whether it was just that the OS restarting that did it ?
Just bought Home Assistant Yellow. Have similar issue.
Getting unknown error or failed to connect when setting up ZHA.
The post above suggested to go to settings > hardware > configure but I cannot find su h option in latest version of home assistant. Any help would be appreciated!
I have the same problem with trying to enable zigbee on the HA Yellow
I completely rebuilt from a new HA yellow image in hope of solving the problem, but no change. at least previously sometimes it would run for a day after a reboot of the yellow, now nothing.
I get “Failed to Connect” as my error message, instead of the message you get above
I tried to enabled debug logging while i installed and nothing is logged at all, so it must be logged else where
