Moved my rPi4b to the Argon 40 and am trying to get i2c enabled so as to control the fan and power button. I can access CLI via a keyboard and HDMI to my TV.
I followed the steps below by entering ‘login’ at the ha prompt which gave me a #
I did not see anyway of going into root (typing in ‘root’ at the ha prompt errored and asked if I meant to type ‘host’ for some reason)
Anyway, I input each line as below and after reboot, typed in login to get # and then lsmod | grep i2c which resulted in i2c_dev 20480 0
But I still get errors about i2c not being enabled when trying to start the Argon40 Add on.
Not sure if I should redo the below with sbd1 or mmcblk0p1 as HA instructions are vague only saying " Type the following to enable I2C, you may need to replace sda1
with sdb1
or mmcblk0p1
depending on your platform" - what platform goes with what???
mkdir /tmp/mnt
mount /dev/sda1 /tmp/mnt
mkdir -p /tmp/mnt/CONFIG/modules
echo -ne i2c-dev>/tmp/mnt/CONFIG/modules/rpi-i2c.conf
echo dtparam=i2c_vc=on >> /tmp/mnt/CONFIG/config.txt
echo dtparam=i2c_arm=on >> /tmp/mnt/CONFIG/config.txt
sync
reboot
