Have a problem where Node Red is saying - Error: EPERM: operation not permitted, open ‘/dev/i2c-0’ when using the node-red-contrib-i2c node. From what I have been able to work out, the issue is the Node Red docker container can’t access the hardware because it doesn’t have permission to do so. The device driver for i2c is in the /dev directory on the RPi4 I’m using (got the driver enabled by using the i2c addon). I started looking into adding the permission to the Node Red config.yaml to access i2c but can’t find it anywhere (and I don’t know if that is the right way to go about it anyway).
