Enabling or Adding Important Readings in TONGOU’s Smart Circuit Breaker (TO-Q-SY2-163JZT) on Zigbee2mqtt
I’m a new user who has installed the TONGOU Smart Circuit Breaker (TO-Q-SY2-163JZT) on Zigbee2mqtt. However, I’m unable to see some important readings such as current intensity, linkquality, power outage memory, update state, and voltage. These readings are crucial for me and I would like to know how to enable or add them. I have attached an image showing the sensors that are not visible. I would greatly appreciate it if anyone has a solution, that the response is not overly technical and is detailed a bit. Any help would be greatly appreciated. I take this opportunity to wish you all a happy New Year’s Eve and New Year’s Day.
Go to Settings > Devices & Services > Entities > Search entities: “General Casa” in your case.
Press CLEAR button to show all entities.
Now all hidden entities showing up and you can enable the entity you want to see/use.
Firstly, I would like to thank you for your prompt response and your help, is this what you are telling me?
I have named my Tongou Circuit Breaker: “PV system rail CB”
When I search for that name, I get:
Then I see “477 entities not shown” and CLEAR button.
Click that button and then next screen appears:
Now you can select that entity you want to modify and press enable:
Hope this will help.
Gracias por su ayuda, realmente me sirvio. Un saludo
can you share the values you can see with zigbee2mqtt?
Hi everyone,
Did you get any response from zigbee2mqtt for about this subject?
you can manually add in zigbee2mqtt using device->reporting and manually find the parameter
