Hi I’m running hassio and I’m try to use either AWS or keyring as shown in this document;
To enable these, do I need to install any software or plugin?
No you don’t have to install any additional software or plugins.
well I can’t run any of the commands to configure it,
$ hass --script check_config --secrets
or
$ hassio --script check_config --secrets
Have you created a secret.yaml file? It is just a text file. If it doesn’t exist the script won’t work. The script does not configure it, it checks it.
I didn’t had to create a secret.yaml file, it was there in hassio by default.
However, for example when I try to follow this
core-ssh:~# hass --script keyring --help
-bash: hass: command not found
Also trying to use this keyring function with Hassio but “–script keyring --help” is not working. “Command not found”…
Using this command give me same result, “–script check_config”… -> “Command not found”.
What to do?
