[END OF LIFE - ABANDONED - DISMISSED] DSS VoIP Notifier
usually is related to EOL chars. But only arm users still having issue.
HA developers have maked big changes to addon’s base images and last update I’ve implemented they on master
Would you try to install old version?
https://github.com/sdesalve/hassio-addons/tree/master/dss_voip34
You’ll find in my addon repository
Works perfectly. Many many thanks! :slight_smile:
Could you try to update original addon and run now?
I’ve switched all file eol to LF using vscode (thanks to Frenk for his suggestion)
Original also works perfectly now. Thanks :slight_smile:
3.5.5 works perfectly, Thanks!
I have some issues to update, so I uninstall the addon and did a new install but I get this message:
Failed to start addon
404 Client Error for http+docker://localhost/v1.40/containers/create?name=addon_89275b70_dss_voip: Not Found (“No such image: 89275b70/armv7-addon-dss_voip:3.5.5”)
What SO do you have in your Raspberry?.
Have you tried to restart HassOs after addon unistall? Restart Raspberry…
Can you try to remove orphan docker images/containers with Portainer addon?
I have cleaned the docker images but now I get this message during install:
Failed to install addon
The command ‘/bin/ash -o pipefail -c apk add --no-cache coreutils=8.32-r2 wget=1.21.1-r1 sox pjsua screen bc’ returned a non-zero code: 6
Raspberry OS is Raspbian GNU/Linux 9 (stretch)
Docker version 19.03.14
HA core-2021.1.5 / supervisor-2021.01.7
Last week another user have experienced same issue but, in his case, was a connection problem.
please connect with a SSH addon (https://github.com/home-assistant/hassio-addons/tree/master/ssh), run this commands and post results:
  • apk add --no-cache coreutils
  • apk add --no-cache wget
  • apk add --no-cache sox
  • apk add --no-cache pjsua
  • apk add --no-cache screen
  • apk add --no-cache bc
It doesn’t solve the issue. I think it’s an version problem?
amazing work sdesalve!!, im trying to configure with spanish main provider, Telefonica Spain, unsucessfully
my computer sip clients works using the following account data, and also a screenshot of my HA addon conf and service call:
i have tried several combinations, with port, no port, any suggest?
thanks!
On my post i haven’t writed version numbers… Do you have copied and pasted my commands?
Please post full terminal output…
yes, adding the proxy with this command it appears to call, but my mobile phone does not rings
added in conf:
pjsua_custom_options: ‘–outbound=sip:10.31.255.134:5070;lr’
Full logs. I can’t help you in this way
Ok which log do you need? entire one o can i capture a part?
dss_autoanswer.log ?
thanks
full addon log
also try to call your number to check if addon answer to calls and you can hear sounds
Here is the complete terminal output:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: DSS VoIP Notifier
 VoIP Notifier for Home Assistant
 Add-on version: 3.5.5
 You are running the latest version of this add-on.
 System: Debian GNU/Linux 10 (buster)  (amd64 / qemux86-64)
 Home Assistant Core: 2021.1.5
 Home Assistant Supervisor: 2021.01.7
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[Info] Starting addon...
PJSUA_CUSTOM_OPTIONS = '--no-tcp --proxy=sip:10.31.255.134:5070;lr'
[Info] Registering as SIP Client...
                  SIP Client registered.
 Call <sip:[email protected]:5060>/VoIP phone number
 to check system status.
 You'll find logs in /share/dss_voip/dss_autoanswer.log
[Info] Listening for messages via stdin service call...
[Info] Received messages {"call_sip_uri": "sip:[email protected]", "message_tts": "Write here your message"}
Converting audio file 'http://192.168.X.XXX:XXXX/api/tts_proxy/3bb4cd06a7898fc0a33665f241cb48f2f2a192ac_es_-_google_translate.mp3'...
Audio succesfully converted...
Starting SIP Client and calling 'sip:[email protected]'...
This call will be terminated after '50' seconds.
17:19:30.468         os_core_unix.c !pjlib 2.9 for POSIX initialized
17:19:30.468         sip_endpoint.c  .Creating endpoint instance...
17:19:30.469                  pjlib  .select() I/O Queue created (0x7fdb20a240f0)
17:19:30.469         sip_endpoint.c  .Module "mod-msg-print" registered
17:19:30.469        sip_transport.c  .Transport manager created.
17:19:30.469           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
17:19:30.488           pjsua_core.c  .pjsua version 2.9 for Linux-4.19.0.13/x86_64 initialized
17:19:30.491            pjsua_app.c  .Turning sound device -99 -99 ON
17:19:30.491                 main.c  Ready: Success
17:19:30.493            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
  [ 0] <sip:172.30.33.7:5060>: does not register
       Online status: Online
 *[ 1] sip:[email protected]:5060: does not register
Buddy list:
 [ 1] <?>  sip:[email protected]
|       Call Commands:         |   Buddy, IM & Presence:  |     Account:      |
|  m  Make new call            | +b  Add new buddy       .| +a  Add new accnt |
|  M  Make multiple calls      | -b  Delete buddy         | -a  Delete accnt. |
|  a  Answer call              |  i  Send IM              | !a  Modify accnt. |
|  h  Hangup call  (ha=all)    |  s  Subscribe presence   | rr  (Re-)register |
|  H  Hold call                |  u  Unsubscribe presence | ru  Unregister    |
|  v  re-inVite (release hold) |  t  ToGgle Online status |  >  Cycle next ac.|
|  U  send UPDATE              |  T  Set online status    |  <  Cycle prev ac.|
| ],[ Select next/prev call    +--------------------------+-------------------+
|  x  Xfer call                |      Media Commands:     |  Status & Config: |
|  X  Xfer with Replaces       |                          |                   |
|  #  Send RFC 2833 DTMF       | cl  List ports           |  d  Dump status   |
|  *  Send DTMF with INFO      | cc  Connect port         | dd  Dump detailed |
| dq  Dump curr. call quality  | cd  Disconnect port      | dc  Dump config   |
|                              |  V  Adjust audio Volume  |  f  Save config   |
|  S  Send arbitrary REQUEST   | Cp  Codec priorities     |                   |
|  q  QUIT   L  ReLoad   sleep MS   echo [0|1|txt]     n: detect NAT type     |
You have 1 active call
Current call id=0 to sip:[email protected] [CALLING]
>>> 17:19:30.531            pjsua_app.c  .....Call 0 is DISCONNECTED [reason=403 (Forbidden)]
17:19:30.531     pjsua_app_common.c  .....
  [DISCONNCTD] To: sip:[email protected]
    Call time: 00h:00m:00s, 1st res in 40 ms, conn in 0ms
17:19:31.491            pjsua_app.c  .Turning sound device -99 -99 OFF
No current call
[Info] Call ended...
sip_parameters:
  caller_id_uri: 'sip:[email protected]:5060'
  realm: '*'
  username: '111111111'
  password: '111111111'
  sip_server_uri: 'sip:telefonica.net:5060'
pjsua_custom_options: '--no-tcp --proxy=sip:10.31.255.134:5070;lr'
Also tried with : pjsua_custom_options: ‘–no-tcp --outbound=sip:10.31.255.134:5070;lr’
addon: 89275b70_dss_voip
input: {"call_sip_uri":"sip:[email protected]","message_tts":"Example Message"}
Other data:
County Code spain: +34
111111111 = Sip account number
22222222 = Destination call number
base_url in google tts setup in your configuration.yaml
