[END OF LIFE - ABANDONED - DISMISSED] DSS VoIP Notifier
EDIT: 2024/12/22
Hello everyone! I’m sorry to announce that I will no give more support for this addon.
If you can find answer to your issue in all this thread you’re welcome. Otherwise please find other solution to make VoIP calls
It was great, bye
Salvatore
Hi!
I’ve started a thread in the Development section but I fear that is not correct place…
I’ve made my FIRST addon for Hassio: DSS VoIP Notifier,
This add-on allows you to make VoIP calls from Hassio ad provides a way to transform a text in a audio file, make a VoIP call to a SIP url and play them to the attendee.
Let me know what do you think about and if you will find it useful!
Bye
SDeSalve
Cool! Will try it :smiley:
Hi @fillwe,
have you tested my add-on? Works well as expected?
Documentation is clear?
Let me know if I can help you.
Best regards
SDeSalve
This addon is great!
It’s perfect for alarm notification.
I used messagenet as voip provider. Here is my configuration_:
  "sip_parameters": {
    "caller_id_uri": "sip:[email protected]",
    "realm": "*",
    "username": "XXXXX",
    "password": "XXXXX",
    "sip_server_uri": "sip:sip.messagenet.it:5061"
  "pjsua_custom_options": "--outbound=sip:sip.messagenet.it:5061;lr"
and as automation:
script:
  test_voip:
    sequence:
    - service: hassio.addon_stdin
      data_template:
        addon: 89275b70_dss_voip
        input: {"call_sip_uri":"sip:[email protected]","message_tts":"Prova messaggio"}
Great job @sdesalve
I do not run hassio, just hass and docker. How would I run this in docker without hassio?
Sorry, I think that is not possible.
I don’t know if you can run an add-on from HomeAssistant…
You can download and edit my run.sh script, adapt to your system, run it as a shell_command and make a call passing parameters…
Let me know if you will be able to make it work as you want
Have a good day
SDeSalve
I should be able to run that dss software in docker though surely?
See FAQ:
Be aware that add-ons are only available in Hass.io, due to the way Hass.io is installed.
I know what a hassio addon is. What I am saying is that there must be a way to run the software in pure docker.
You can copy/fork his repo the use the dockerfile in a github repo that dockerhub can build for you.
Or you can build the docker image directly from his dockerfile.
WOOOW
Ottimo addon!
Facilissimo da configurare e porta l’ultima funzione che mancava per diventare davvero una allarme in grado di sostituire la classica.
Sviluppatore sempre pronto ad aiutare e molto competente.
Great Job!
Yeah I am building up to that :slight_smile:
Still learning docker!
I must study docs, thanks. I don’t know how I can run a script in a docker from shell.
Thanks for your suggestions!
absolutely, can’t waitr to try it
No HACS is not for running separate applications or daemons, it is for custom components, lovelace cards, themes, python scripts and appdaemon apps.
Hi, I have a messagenet number (I forgot I had :smiley: ) which is +3906zzzzz
Which are the sip_parameters (sip:[email protected], what is xxx the username??)
Also the username is the "Numero interno: 53xxxx ? Or the username to access messagenet??
See attached image for username and other parameters for messagenet
Yes should be 53xxx
Thanks now its clear the username and password, but syill not sure about what to put after sip:
I check now with the username
EDIT: yes its the “Numero interno”
  "sip_parameters": {
    "realm": "*",
    "username": "53XXX",
    "password": "XxXXX",
