[END OF LIFE - ABANDONED - DISMISSED] DSS VoIP Notifier
i’ve tried to install that version but it gives me this error
‘Connection aborted.’, ConnectionResetError(104, 'Connection reset by peer
Full logs…
how can igive you any logs if when i click istall it won’t let me? that’s the message that appears when i click on the istall button
I’ve not understood that error was during setup… Was not specified, sorry
Post your hassio Supervisor error logs and info about your hassio setup… Do you have fully supported hassio? Raspbian or anything else?
With ARM processors you must use arm version… Otherwise it will not place any call
Try to update to the last hassio/hassos version, reboot your host machine and try to install
sorry if i came of rude it was not my intention
anyway this is the line that appear in the supervisor log when i try to istall the arm version
22-07-27 00:13:51 ERROR (SyncWorker_4) [supervisor.utils.json] Can’t read json from /data/addons/git/89275b70/dss_voipARM/build.json: Expecting property name enclosed in double quotes: line 7 column 5 (char 213)
22-07-27 00:13:51 INFO (SyncWorker_4) [supervisor.docker.addon] Starting build for 89275b70/armv7-addon-dss_voipARM:4.0.0
22-07-27 00:13:52 ERROR (SyncWorker_4) [supervisor.docker.addon] Can’t build 89275b70/armv7-addon-dss_voipARM:4.0.0: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
22-07-27 00:14:04 ERROR (SyncWorker_5) [supervisor.utils.json] Can’t read json from /data/addons/git/89275b70/dss_voipARM/build.json: Expecting property name enclosed in double quotes: line 7 column 5 (char 213)
22-07-27 00:14:04 INFO (SyncWorker_5) [supervisor.docker.addon] Starting build for 89275b70/armv7-addon-dss_voipARM:4.0.0
22-07-27 00:14:05 ERROR (SyncWorker_5) [supervisor.docker.addon] Can’t build 89275b70/armv7-addon-dss_voipARM:4.0.0: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
i’ve an home assistant supervised install on top of raspbian buster (2022.7.7)
i’ve rebooted the host like you suggested but nothing has changed
Quite possibly your problem is that buster is not supported, only bullseye. Nor is raspbian officially supported, only debian. Having said that I have seen many reports that raspbian does work, but of course you’d need to go up to bullseye.
sorry i’m an idiot i meant bullseye
Thank you for the add-on. However, for some reason, it’s not working for me. The log shows that everything is working but I’m not getting the call.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: DSS VoIP Notifier
 VoIP Notifier for Home Assistant
 Add-on version: 4.0.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 8.4  (amd64 / qemux86-64)
 Home Assistant Core: 2022.8.1
 Home Assistant Supervisor: 2022.07.0
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[Info] Starting addon...
[Info] Listening for messages via stdin service call...
[Info] Received messages {"call_sip_uri":"sip:110@myipis here:5060","message_tts":"Write here your message"}
Converting audio file 'http://HAip:8123/api/tts_proxy/3bb4cd06a7898fc0a33665f241cb48f2f2a192ac_en_-_google_translate.mp3'...
Audio succesfully converted...
Starting SIP Client and calling 'sip:110@myipis here:5060'...
This call will be terminated after '50' seconds.
18:55:50.871         os_core_unix.c !pjlib 2.11.1 for POSIX initialized
18:55:50.875         sip_endpoint.c  .Creating endpoint instance...
18:55:50.876                  pjlib  .select() I/O Queue created (0x7f651a0e7100)
18:55:50.876         sip_endpoint.c  .Module "mod-msg-print" registered
18:55:50.876        sip_transport.c  .Transport manager created.
18:55:50.876           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
18:55:50.917           pjsua_core.c  .pjsua version 2.11.1 for Linux-5.15.55/x86_64 initialized
18:55:50.934            pjsua_app.c  .Turning sound device -99 -99 ON
18:55:50.934                 main.c  Ready: Success
18:55:50.945            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
  [ 0] <sip:172.30.33.3:5060>: does not register
       Online status: Online
  [ 1] <sip:172.30.33.3:5060;transport=TCP>: does not register
 *[ 2] sip:110@myipis here:5060: does not register
Buddy list:
 [ 1] <?>  sip:110@myipis here:5060
|       Call Commands:         |   Buddy, IM & Presence:  |     Account:      |
|  m  Make new call            | +b  Add new buddy       .| +a  Add new accnt |
|  M  Make multiple calls      | -b  Delete buddy         | -a  Delete accnt. |
|  a  Answer call              |  i  Send IM              | !a  Modify accnt. |
|  h  Hangup call  (ha=all)    |  s  Subscribe presence   | rr  (Re-)register |
|  H  Hold call                |  u  Unsubscribe presence | ru  Unregister    |
|  v  re-inVite (release hold) |  t  ToGgle Online status |  >  Cycle next ac.|
|  U  send UPDATE              |  T  Set online status    |  <  Cycle prev ac.|
| ],[ Select next/prev call    +--------------------------+-------------------+
|  x  Xfer call                |      Media Commands:     |  Status & Config: |
|  X  Xfer with Replaces       |                          |                   |
|  #  Send RFC 2833 DTMF       | cl  List ports           |  d  Dump status   |
|  *  Send DTMF with INFO      | cc  Connect port         | dd  Dump detailed |
| dq  Dump curr. call quality  | cd  Disconnect port      | dc  Dump config   |
|                              |  V  Adjust audio Volume  |  f  Save config   |
|  S  Send arbitrary REQUEST   | Cp  Codec priorities     |                   |
|  q  QUIT   L  ReLoad   sleep MS   echo [0|1|txt]     n: detect NAT type     |
You have 1 active call
Current call id=0 to sip:110@myipis here :5060 [CALLING]
System Information
version core-2022.8.1
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.10.5
os_name Linux
os_version 5.15.55
arch x86_64
timezone Asia/Riyadh
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 4599
Installed Version 1.26.2
Stage running
Available Repositories 1070
Downloaded Repositories 8
Home Assistant Cloud
logged_in true
subscription_expiration January 1, 2018, 3:00 AM
relayer_connected false
remote_enabled false
remote_connected false
alexa_enabled true
google_enabled true
remote_server null
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
host_os Home Assistant OS 8.4
update_channel stable
supervisor_version supervisor-2022.07.0
agent_version 1.2.1
docker_version 20.10.14
disk_total 30.8 GB
disk_used 6.3 GB
healthy true
supported true
board ova
supervisor_api ok
version_api ok
installed_addons File editor (5.3.3), Cloudflared (2.0.6), Samba share (10.0.0), Mosquitto broker (6.1.2), DSS VoIP Notifier (4.0.0)
Dashboards
dashboards 2
resources 2
views 3
mode storage
Recorder
oldest_recorder_run July 27, 2022, 10:45 AM
current_recorder_run August 5, 2022, 10:30 AM
estimated_db_size 793.36 MiB
database_engine sqlite
database_version 3.38.5
what’s “myipis here”? here you must set your account SIP server address/IP
please add base_url with your public HA URL
If SIP address of VoIP is correct and you don’t have setted in that parameter you hassio IP, try also
pjsua_custom_options: '--no-tcp'
I redacted The IP addresses here is the log after adding pjsua_custom_options: '--no-tcp'
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
PJSUA_CUSTOM_OPTIONS = '--no-tcp'
[Info] Received messages {"call_sip_uri":"sip:[email protected]:5060","message_tts":"Write here your message"}
Converting audio file 'http://10.18.100.231:8123/api/tts_proxy/3bb4cd06a7898fc0a33665f241cb48f2f2a192ac_en_-_google_translate.mp3'...
Starting SIP Client and calling 'sip:[email protected]:5060'...
21:24:52.909         os_core_unix.c !pjlib 2.11.1 for POSIX initialized
21:24:52.910         sip_endpoint.c  .Creating endpoint instance...
21:24:52.910                  pjlib  .select() I/O Queue created (0x7fc2a182e100)
21:24:52.910         sip_endpoint.c  .Module "mod-msg-print" registered
21:24:52.910        sip_transport.c  .Transport manager created.
21:24:52.910           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
21:24:52.924           pjsua_core.c  .pjsua version 2.11.1 for Linux-5.15.55/x86_64 initialized
21:24:52.928            pjsua_app.c  .Turning sound device -99 -99 ON
21:24:52.928                 main.c  Ready: Success
21:24:52.929            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
 *[ 1] sip:[email protected]:5060: does not register
Buddy list:
 [ 1] <?>  sip:[email protected]:5060
Current call id=0 to sip:[email protected]:5060 [CALLING]
>>> 21:24:53.928            pjsua_app.c  .Turning sound device -99 -99 OFF
21:25:24.929            pjsua_app.c  ....Call 0 is DISCONNECTED [reason=408 (Request Timeout)]
No current call
>>> 21:25:44.442                timer.c  .Dumping timer heap:
21:25:44.442                timer.c  .  Cur size: 0 entries, max: 3070
[Info] Call ended...
and this is it without it
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
21:26:38.350         os_core_unix.c !pjlib 2.11.1 for POSIX initialized
21:26:38.350         sip_endpoint.c  .Creating endpoint instance...
21:26:38.351                  pjlib  .select() I/O Queue created (0x7fb544eba100)
21:26:38.351         sip_endpoint.c  .Module "mod-msg-print" registered
21:26:38.351        sip_transport.c  .Transport manager created.
21:26:38.351           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
21:26:38.364           pjsua_core.c  .pjsua version 2.11.1 for Linux-5.15.55/x86_64 initialized
21:26:38.369            pjsua_app.c  .Turning sound device -99 -99 ON
21:26:38.369                 main.c  Ready: Success
21:26:38.369            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
 *[ 2] sip:[email protected]:5060: does not register
Buddy list:
>>> 21:26:39.370            pjsua_app.c  .Turning sound device -99 -99 OFF
21:27:10.370            pjsua_app.c  ....Call 0 is DISCONNECTED [reason=408 (Request Timeout)]
No current call
>>> 21:27:29.879                timer.c  .Dumping timer heap:
21:27:29.879                timer.c  .  Cur size: 0 entries, max: 3070
And both times this was my serves call
service: hassio.addon_stdin
data: {
        addon: 89275b70_dss_voip,
        input: {"call_sip_uri":"sip:[email protected]:5060","message_tts":"Write here your message"}
By the way when I monitor my 3cx admin panel I noticed there is no calls being made.
Your local Lan is 10.18.100.*?
Your HA IP is 10.18.100.231?
Your local 3cx server is 10.18.100.157?
yes to all
and I just remembered I’m using port 4060 because it conflict with my STC (ISP provider) router.
in my Grandstream HT813 I’m using UDP
the log after editing the port
[cont-init.d] done.
[services.d] done.
[Info] Received messages {"call_sip_uri":"sip:[email protected]:4060","message_tts":"Write here your message"}
Starting SIP Client and calling 'sip:[email protected]:4060'...
22:16:18.748         os_core_unix.c !pjlib 2.11.1 for POSIX initialized
22:16:18.749         sip_endpoint.c  .Creating endpoint instance...
22:16:18.750                  pjlib  .select() I/O Queue created (0x7f292cb84100)
22:16:18.750         sip_endpoint.c  .Module "mod-msg-print" registered
22:16:18.750        sip_transport.c  .Transport manager created.
22:16:18.750           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
22:16:18.766           pjsua_core.c  .pjsua version 2.11.1 for Linux-5.15.55/x86_64 initialized
22:16:18.773            pjsua_app.c  .Turning sound device -99 -99 ON
22:16:18.773                 main.c  Ready: Success
22:16:18.775            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
 *[ 1] sip:[email protected]:4060: does not register
Buddy list:
 [ 1] <?>  sip:[email protected]:4060
Current call id=0 to sip:[email protected]:4060 [CALLING]
>>> 22:16:18.849      tsx0x7f292c9f36d8  .......Temporary failure in sending Request msg INVITE/cseq=2547 (tdta0x7f292c9ecaa8), will try next server: Unsupported transport (PJSIP_EUNSUPTRANSPORT)
22:16:19.118            pjsua_app.c  .....Call 0 state changed to EARLY (180 Ringing)
22:16:19.118            pjsua_app.c  .....Call 0 state changed to CONNECTING
22:16:19.123            pjsua_app.c  .....Call 0 state changed to CONFIRMED
22:16:19.416     pjsua_app_common.c  .......
  [CONFIRMED] To: sip:[email protected];tag=c61a1115
    Call time: 00h:00m:00s, 1st res in 345 ms, conn in 350ms
    #0 audio speex @8kHz, sendrecv, peer=-
       SRTP status: Not active Crypto-suite:
       RX pt=97, last update:00h:00m:00.000s ago
          total 0pkt 0B (0B +IP hdr) @avg=0bps/0bps
          pkt loss=0 (0.0%), discrd=0 (0.0%), dup=0 (0.0%), reord=0 (0.0%)
                (msec)    min     avg     max     last    dev
          loss period:   0.000   0.000   0.000   0.000   0.000
          jitter     :   0.000   0.000   0.000   0.000   0.000
       TX pt=97, ptime=20, last update:never
          total 15pkt 570B (1.1KB +IP hdr) @avg=15.3Kbps/31.4Kbps
          pkt loss=0 (0.0%), dup=0 (0.0%), reorder=0 (0.0%)
       RTT msec      :   0.000   0.000   0.000   0.000   0.000
22:16:22.994     pjsua_app_common.c  ........
  [DISCONNCTD] To: sip:[email protected];tag=c61a1115
    Call time: 00h:00m:03s, 1st res in 345 ms, conn in 350ms
          total 86pkt 3.0KB (6.4KB +IP hdr) @avg=6.8Kbps/14.4Kbps
22:16:22.994            pjsua_app.c  ......Call 0 is DISCONNECTED [reason=200 (Normal call clearing)]
22:16:23.994            pjsua_app.c  .Turning sound device -99 -99 OFF
No current call
>>> 22:17:10.285                timer.c  .Dumping timer heap:
22:17:10.285                timer.c  .  Cur size: 0 entries, max: 3070
Has ringed? Did you hear anything when pickup receiver?
didn’t even ring and nothing in 3cx log or call record
update
it’s working. it was the port. Then I realized that I was calling the same extension :sweat_smile:
Thank you
So I use my home assistant google tts in English and Arabic. If you want to use other languages, you can jus keep adding Google TTS intros just like this
tts:
  - platform: google_translate
    service_name: google_translate_say_ar
    language: 'ar'
    service_name: google_translate_say_sp
    language: 'sp'
and write your message in that languages keyboard layout
Arabic message
data: {
        input: {"call_sip_uri":"sip:[email protected]:4060","message_tts":"مرحباً بكم"}
Why can’t I install the ARM version? It always gives:
The normal (non-ARM) version instead installs just fine.
I’m running on a Raspberry Pi 4 - so I thought I better take the ARM version…
Try the normal version.
Sometimes on raspberry call will not be placed with new addon base image. So I left old addon base image and make an ARM Version…
so i’m not the only one with this problem
@sdesalve sorry to bother you again but i didn’t understood one thing the problem with the non-arm version istalled on arm causes issues sometimes or everytime? because from the response you gave me i assumed it was everytime
Yes, on some system the called extension will not ring and call will not be placed
I have been able to get everything working: my configuration is HA in container, with fritzbox, and the tests with audio_file_url are successful.
Now I’d like to change it using tts picotts: I tried that, but when it should make the call, the integration crashes (and the watchdog restarts it).
At the moment I’m using google_say, but I don’t know if this is my problem or if dss_voip can’t work with picotts.
Thanks anyway for this great addon!!
Configs:
configuration.yaml
# Text to speech
tts:
  - platform: picotts
    language: "it-IT"
DSS_Voip_notifier:
sip_parameters:
  caller_id_uri: sip:[email protected]
  realm: "*"
  username: voip-test1
  password: test_voip1
pjsua_custom_options: "--no-tcp  --ip-addr=192.168.1.100"
max_call_time: 20
Automation:
alias: Test telefonata
description: ""
  - platform: state
    entity_id:
      - input_boolean.prevent_deep_sleep
condition: []
  - service: hassio.addon_stdin
    data_template:
      input:
        call_sip_uri: sip:392*******@192.168.1.1:5060
        message_tts: Prova segnalazione allarme
