Hello HA community!
I’m just starting out and trying to get my head around it. I started with heating thermostats (+ TV and printer), now roller shutters and light switches will follow (the BSEED brand is planned). I’m happy to be here and to be able to help others at some point:smiley:
This switch is about:
BSEED roller shutter switch
TS130F
by _TZ3000_vsj5o7dm
My HA runs over RPi5, with a Conbee3 Zigbee stick.
What have I done so far:
First I had the 4 thermostats running via zigbee2mqtt. Everything worked too. But now I have the switches with which I would like to equip two floors. But it is not supported by Z2M. That’s why I went back to ZHA. I was also able to integrate the switch there and it works up and down.
Problem:
It doesn’t go all the way up.
Using TuyaCoveringCluster, I adjusted the current_position_lift_percentage attribute so that it goes all the way up. But then it no longer goes all the way down. The total travel time that the switch allows the roller blind to move is too short. I just can’t get it set. Can someone help me? I’ve been trying around for hours but can’t get any further…
Or is there a way to get the switch to work in z2m?
It would probably also be possible with a Tuya add-on - but then it would run over WLAN or I would need a Tuya gateway, right?
Thank you very much for your help and I apologize in advance for the newbee question: wink:
Best regards
Schlejan
