ENER-J Smart WiFi Touch Switch 2 Gang
I’ve just bought one of their double sockets. What did you need to do to flash them with ESPhome?
I compiled the *.bin file within esphome and then flashed the socket using tuya-convert which I had setup on an old pi.
Check out this thread;
Got it. Awesome. Thanks.
I’ll have to go beg to borrow a friend’s Pi.
What did your final esp node yaml look like? How did you figure the GPIO numbers out?
@ Holdestmade esphome config worked first time. I had to do some poking around with the 2 gang light switch though to discover what gpio’s were where. But shall change the domain from “switch” to “light” before I install it.
So did you ever manage to sort this?
Yes, it works.
Thanks for your reply Lev!
I’m a complete newbie on Home assistant (Raspberry Pi came today!) and I want to make touch screen tablets in my house at certain entrances etc. I’m assuming Ener-J switched are not compatible with HA so would I need to flash them?
I’m having trouble trying to compile the yaml to get a bin file. It validates fine.
Blockquote
INFO Reading configuration /config/esphome/7IG.yaml…
INFO Generating C++ source…
INFO Compiling app…
INFO Running: platformio run -d /config/esphome/tasmota_91ad26-3366
Processing tasmota_91ad26-3366 (board: esp01_1m; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
PACKAGES:
  • framework-arduinoespressif8266 3.20704.0 (2.7.4)
  • tool-esptool 1.413.0 (4.13)
  • tool-esptoolpy 1.20800.0 (2.8.0)
  • toolchain-xtensa 2.40802.200502 (4.8.2)
    Library Manager: Installing Update
    Library Manager: Already installed, built-in library
    Dependency Graph
    |-- 1.2.3
    | |-- 1.0
    |-- 1.0
    |-- 1.2
    | |-- 1.0
    |-- 1.2.7
    | |-- 1.2.3
    | | |-- 1.0
    | |-- 1.0
    | |-- 1.0
    |-- 1.1.1
    | |-- 1.0
    Retrieving maximum program size /data/tasmota_91ad26-3366/.pioenvs/tasmota_91ad26-3366/firmware.elf
    Checking size /data/tasmota_91ad26-3366/.pioenvs/tasmota_91ad26-3366/firmware.elf
    RAM: [==== ] 45.0% (used 36836 bytes from 81920 bytes)
    Flash: [==== ] 39.1% (used 400132 bytes from 1023984 bytes)
    ========================= [SUCCESS] Took 5.88 seconds =========================
    INFO Successfully compiled program.
    INFO Resolving IP address of tasmota_91ad26-3366.local
    ERROR Error resolving IP address of tasmota_91ad26-3366.local. Is it connected to WiFi?
    ERROR (If this error persists, please set a static IP address: WiFi Component — ESPHome)
    ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
Looks like it has compiled the bin file, the error was in resolving the IP of the device.
Hi Lev,
Using your config, the flashed devices work on home assistant but the hardware buttons don’t work for one of the switches. I’ve flashed three sockets and they all have the same issue. It’s always the the right hand side switch that won’t work physically but I can turn it on and off using home assistant. Any help would be appreciated. Thanks.
If you pushed the config for the light switch into the socket then it will not work, I remember having to poke around to find the correct GPIO pinout for the lightswitch, push the config from this thread to the sockets Ener-j Smart WiFi Weatherproof Double Socket
Also, you want to change the domain from “switch” to “light” when flashing the light switches, that was a hangover from the socket config copied and pasted!
How do I change the domain?
I’m flashing Ener-J light switches btw…
Change the config here,
The buttons are working on mine, only thing I can think is that there may be some update or change on the pinout, cant recall but do they have any sticker with revision number, will have a look to see if there is anything on mine.
I’ve changed what you mentioned above - from “switch” to “light”…this is the error code when I validate…
Failed config
binary_sensor.gpio: [source /config/esphome/switch1.yaml:32]
  platform: gpio
  pin:
    number: GPIO13
    mode: INPUT_PULLUP
    inverted: True
  on_click:  [source /config/esphome/switch1.yaml:39]
    - [source /config/esphome/switch1.yaml:39]
      Unable to find action with the name 'switch.toggle'.
      switch.toggle: right_relay [source /config/esphome/switch1.yaml:39]
binary_sensor.gpio: [source /config/esphome/switch1.yaml:41]
  platform: gpio
  pin:
    number: GPIO12
    mode: INPUT_PULLUP
    inverted: True
  on_click:  [source /config/esphome/switch1.yaml:48]
    - [source /config/esphome/switch1.yaml:48]
      switch.toggle: left_relay [source /config/esphome/switch1.yaml:48]
light.gpio: [source /config/esphome/switch1.yaml:51]
  Platform not found: 'light.gpio'.
  platform: gpio
  pin:
    number: GPIO04
  icon: mdi:lightbulb
light.gpio: [source /config/esphome/switch1.yaml:58]
  platform: gpio
  pin:
    number: GPIO13
  icon: mdi:lightbulb
This is my config yaml
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "Main Hub"
  password:
  manual_ip:
    static_ip: 192.168.86.150
    gateway: 192.168.86.1
    subnet: 255.255.255.0
    dns1: 192.168.86.1
    dns2: 192.168.86.1
  ap:
    ssid: "Switch1 Fallback Hotspot"
    password: "sunLVrwTadoV"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      mode: INPUT_PULLUP
      inverted: True
    on_click:
      - switch.toggle: right_relay
  - platform: gpio
    pin:
      number: GPIO12
      mode: INPUT_PULLUP
      inverted: True
    on_click:
      - switch.toggle: left_relay
light:
  - platform: gpio
    pin:
      number: GPIO04
    icon: mdi:lightbulb
  - platform: gpio
    pin:
      number: GPIO13
    icon: mdi:lightbulb
change to light.toggle
Or use Light Switch Integration.
Getting this error message now - I will try the light switch link…
Failed config
light.gpio: [source /config/esphome/kitchenswitch1.yaml:51]
  platform: gpio
  pin:
    number: GPIO04
  icon: mdi:lightbulb
light.gpio: [source /config/esphome/kitchenswitch1.yaml:58]
  platform: gpio
  pin:
    number: GPIO13
  icon: mdi:lightbulb``
