Hi All
Hope you can help
I am trying to get a value from an Energie mi home Radiator value, and try as I may I cannot get it to read back (probably through my in experience in json
I have a light on Home assistant with the codes Below in configuration .yaml working just fine so I have tried to amend this to suit in a sensor to no luck
switch:
stairs_switch:
command_on: ‘curl -u “email:password” -X POST -H “Content-Type: application/json” -d “{“id”:150092}” https://mihome4u.co.uk/api/v1/subdevices/power_on’
command_off: ‘curl -u “email:password” -X POST -H “Content-Type: application/json” -d “{“id”:150092}” https://mihome4u.co.uk/api/v1/subdevices/power_off’
friendly_name: Stairs LED
This works ok
Trying to put it into a sensor I have tried multiple stuff but cannot get it to work. I just get unavailable on this code
- platform: command_line
command: ‘“email:password” -X POST -H “Content-Type: application/json” -d “{“id”:146015}” https://mihome4u.co.uk//api/v1/subdevices/reported_temperature"’
The API information for anyone who can help is
https://mihome4u.co.uk/docs/api-documentation/subdevices-api/fetch-usage-data
Thanks in advance and a Merry Christmas to all
p.s Indenting is correct in configuration file
Paul
