Energy and NorthQ
It looks great with the new energy possibilities, I have a Northq “energy monitor” that report my grid consume every 15 min via Z-wave, it works fine and my entity is named “sensor.northq_nq_92021_power_reader_energy”. If select “Energy” in the menu, then nothing shows under “Add Consumption” – how do I get it in there?
I do not have solar panels.
Hi
I’m interested in a NorthQ PowerReader, too.
Did you find a solution for this issue?
No - I have not get any reply. And I don’t know how to move on. I have also been busy with other areas, so it’s still on my to do list to figure out how
Hey, did you ever get it to work?
I had the same problem but it turned out that I did not have sensors reporting to the recorder.
I have the NorthQ Power Meter as well but I can’t get it to work with HA, it pairs fine but the reporting is terrible, tried to change the real time mode from 15 minutes to ever 2 minutes but it will not report the data. If i’m lucky I get readings 4 times a day.
Yes, have just migrated to z-wave JS and it seems that data is coming in and also the Energy monitoring is working.
I can se that I drain battery, more than normal, form NorthQ - this might indicate that it’s not going into sleep mode.
