Energy Config Error (fixed see below)
Getting an error when i try to access the Energy section in the config menu
Literally no idea what is going on as the rest of the install seems fine
Can anyone help please
Log as I see it
Logger: homeassistant.components.websocket_api.http.connection
Source: components/energy/validate.py:300
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 19:40:58 (5 occurrences)
Last logged: 19:46:52
[547356929232] Error handling message: Unknown error
[547690630112] Error handling message: Unknown error
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
    await func(hass, connection, msg)
  File "/usr/src/homeassistant/homeassistant/components/energy/websocket_api.py", line 167, in ws_validate
    connection.send_result(msg["id"], (await async_validate(hass)).as_dict())
  File "/usr/src/homeassistant/homeassistant/components/energy/validate.py", line 300, in async_validate
    hass.data[DOMAIN]["cost_sensors"][flow["stat_energy_from"]],
KeyError: ''
Same ERROR here
Fixed mine. Goto config/.storage and delete the file ‘energy’
it then recreates the file without errors
I used samba to get in but you could use the terminal
