Energy configuration option missing in config menu
Hi all,
Bit of a weird thing: when I dive into the configuration menu (not the file) I cannot find the “energy” option anymore. It seems to have disappeared. The energy dashboard is available however, I set it up a month ago. Does anyone know what’s wrong? I have tried to rename the energy file to energy
.old, but that only resets the dashboard and does not bring back the configuration menu option.
Some extra info:
|Version |core-2022.2.5|
|Installation Type |Home Assistant OS|
|Host Operating System |Home Assistant OS 7.3|
|Update Channel |stable|
|Supervisor Version |supervisor-2022.01.1|
Yes. You didn’t read the release notes before updating.
It’s the very first breaking change.
Excellent, we have an explanation. Thanks
I’m not sure I’m following the above. Yeah, I can see the Energy menu option available on the console menu however I’m not able to actually edit the configuration.
Assume the below image shows the menu option being referred to?
Cheers,
Paul
Screenshot 2022-04-04 at 09-06-18 2022 2 Let's start streamlining
Got it, cheers.
what do you do if you deleted the energy dashboard under dashboards and now you can’t create it again?
Add this to your configuration.yaml file and restart:
energy:
