I got another 4 of these flashed without much drama. Much easier and faster after you’ve done your first.
There’s an opportunity to use these things as ble scanners (or bluetooth proxies?).
But I know those things are memory intensive, so maybe not a good idea.
I had a go at using a common config using include
In the devices yaml (arlec-smartplug-3.yaml)
<<: !include .arlec-smartplug-common.yaml
esphome:
friendly_name: Arlec Smartplug 3
comment: "Arlec White Grid Connect Smart Plug in Socket with Energy Meter"
wifi:
ap:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.131
gateway: 192.168.1.1
subnet: 255.255.255.0
in .arlec-smartplug-common.yaml
# Config for Arlec White Grid Connect Smart Plug in Socket with Energy Meter
# Product Code: PC191HA (White) & PC191BKHA (Black). “Series 2” (CB2S module, BK7231N chip)
# https://www.bunnings.com.au/arlec-white-grid-connect-smart-plug-in-socket-with-energy-meter_p0273367
# https://upk.libretiny.eu/?profile=arlec-pc191ha-smart-plug-bk7231n-v1.1.8
# Copied some config from Athom: https://github.com/athom-tech/athom-configs/blob/e9d1218fe0d8b4631cda211d204dd3ff5ac698be/athom-smart-plug-v2.yaml
substitutions:
relay_restore_mode: RESTORE_DEFAULT_OFF #Adjust as required.
hlw8012_update_interval: 30s #Not sure how this affects lifetime and maybe overheating?
bk72xx:
board: generic-bk7231n-qfn32-tuya #https://docs.libretiny.eu/boards/cb2s/
logger:
mdns:
api:
password: ""
ota:
password: ""
globals:
- id: total_energy
type: float
restore_value: yes
initial_value: '0.0'
- platform: uptime
- platform: wifi_signal
update_interval: 60s
- platform: hlw8012
model: BL0937
update_interval: ${hlw8012_update_interval}
change_mode_every: 3
voltage_divider: 770 #Required changing
current_resistor: 0.001 ohm
cf_pin:
number: P8
inverted: true
cf1_pin:
number: P7
inverted: true
sel_pin:
number: P6
inverted: true
current:
filters:
- multiply: 0.4250 #https://community.home-assistant.io/t/esphome-install-does-not-update-firmware/544026/10?u=mahko_mahko
- lambda: if (x < 0.01) {return 0;} else {return x;}
voltage:
power:
filters:
- multiply: 0.97
energy:
unit_of_measurement: kWh
filters:
- multiply: 0.001 # Multiplication factor from W to kW is 0.001
on_value:
then:
- lambda: |-
static float previous_energy_value = 0.0;
float current_energy_value = id(energy).state;
id(total_energy) += current_energy_value - previous_energy_value;
previous_energy_value = current_energy_value;
device_class: "energy"
state_class: "total_increasing"
icon: "mdi:lightning-bolt"
accuracy_decimals: 3
lambda: |-
return id(total_energy);
- platform: total_daily_energy
name: "Total Daily Energy"
restore: true
power_id: power_sensor
filters:
- multiply: 0.001
output:
- platform: libretiny_pwm
pin:
number: P23
inverted: true
light:
- platform: monochromatic
output: output_led_1
binary_sensor:
- platform: gpio
pin:
number: P10
inverted: true
mode: INPUT_PULLUP
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at least 0.2s
then:
- switch.toggle: switch_1
- timing:
- ON for at least 4s
then:
- button.press: Reset
switch:
- platform: gpio
pin: P24
on_turn_on:
- light.turn_on: light_switch_1
on_turn_off:
- light.turn_off: light_switch_1
restore_mode: ${relay_restore_mode}
status_led:
pin:
number: P26
inverted: true
text_sensor:
version:
- platform: wifi_info
ip_address:
ssid:
mac_address:
button:
- platform: factory_reset
name: "Restart with Factory Default Settings"
- platform: safe_mode
internal: false
time:
- platform: sntp
