Trying to determine how HA calculates the energy used in the home as I am seeing two different values coming from HA and from my inverter.
Example today says used 36.8kwh
However the inverter reports only: 34.7kwh
I see now, thanks for that.
The monthly usage in HA is 855kwh and inverter (real) is 800kwh, so the HA value is pretty much useless as it only applies if net metering, which is not a thing for me
I guess the value is correct if not exporting anything.
Wish there was a way to pass the consumption value from the inverter.
Or close enough, some of the values update in HA every hour so a little off and the grid used comes from a shelly EM not the inverter hence the little discrepancy
