I run a small balcony solar system producing max 600 W. My inverter is the Deye 600 connected to HA via the solarman integration. Production is reported with 0.1 accuracy.
When I add the production to the energy dashboard, I assume I need to configure the Daily Production
sensor and not the Total Production
sensor?
I actually use the Total Production
, as I do with my (two) consumer sensors. But with this I see netto production of 15 kWh, although I have produced just 6 kWh.
If I configure it with Daily Production
as i.e. discussed here, it’s for smaller PV plants with low production fairly useless.
But with a small solar system the daily production often (half of a cloudy day) reports just 0.0 kWh. The total consumption summarizes those small parts and would be more nearer to the truth.
Assumed your panels produce (just to explain) 0,09 kWh per day.
Daily day 1: 0,0 kWh - Total day 1 0.0 kWh → Daily day 1: 0.0 kWh
Daily day 2: 0.0 kWh - Total day 2 0.1 kWh → Daily day 2: 0.1 kWh
Daily day 3: 0.0 kWh - Total day 3 0.2 kWh → Daily day 3: 0.1 kWh
Here my values from today: Started with Daily: 0.0 and Total 6.0. During the day Total switched to 6.1 although the Daily was still 0 (till end of day).
