Energy dashboad disappeared after update
After new installation, energy dashboard disappeared from sidebar. However, it is also not in the new menu system.
I looked in the documentation default_config must be enabled in configuration.yaml. This is enabled for me.
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
With notification it says:
The following integrations and platforms could not be set up:
  • energy
  • default_config
When I go to energy configuration on the page above I get the message:
This redirect is not supported by your Home Assistant instance. You need the integration energy to use this redirection.
Can anyone advise what I should do to get the energy dashboard back?
Peter
I have the same problem, I also end up with - “This redirect is not supported by your Home Assistant instance. You need the integration energy to use this redirection.”
I dit a server restart and after that is was back in both menu’s
Even after a system reset I get “This redirect is not supported by your Home Assistant instance. You need the integration energy to use this redirection.” when I go to energy configuration on the page above. I have
default_config:
in the configuration,yaml
This problem appears with me as well. Not every day, not every week, a restart will resolve the issue. Anyone that has a clue or knows where to start searching to understand this problem? Summary: the Energy dashboard is away from the menu (left) but still captures data. When I restart (full) the dashboard appears again until a few days/week.
