Hi all
At home I have a 3-phase installation with solar panels hooked up to only 1 phase.
This means that I may be returning energy on 1 phase while consuming on the other 2.
To me personally, this doesn’t make a difference as the utility provider sums the phases together and will substract whatever return I have on the PV phase from the other phases.
However, in the Energy Dashboard this is seen as separate consumption and production, which has a few side-effects:
- The self-consumption statistic doesn’t match with what I would calculate based on my electricity bill.
- The visual with the grid, panels, and house shows lots of energy exported and practically the same number imported again (depending on my actual consumption at the time).
- The cost calculations don’t match my bill as in HA injection tarrif would be granted for 1 phase and electricity would be purchased on the other 2, while my bill may have a zero-sum for that moment.
My request is for a toggle that would cause the consumption and production across phases to be summed.
This way – in the calculations – I’d have 1 number for consumption and 1 for production.
Whether or not the UI still shows this as 4 seperate (3 in, 1 out) blocks, doesn’t really matter for me personally.
Note that the calculations would have to be real-time, i.e. not the sum of 1 hour of data but as short of a time-period as possible.
Example
- On Phase A I am consuming 250,2W
- On Phase C I am consuming 3,4W
- On Phase B (PV phase) I am returning 1.457,5W
- Not shown here is the production of the PV, let’s assume 1.500W (cloudy day)
Assuming these numbers where static for 1 hour:
- My utility provider would pay me injection tarrif for 1.203,9Wh. Their dashboard would not show consumption for that hour.
- Energy Dashboard would show me 253,6Wh of energy consumed and 1.457,5Wh produced.
- I would have 100% self-consumption according to my provider, while the Energy Dashboard would only show me 2,83% being
( [PV production] - [Phase B return] ) / [PV production]
or(1.500 - 1.457,5 {= 42,5}) / 1.500
