Hey Community
I updated May 19. to the Home Assistant version 2023.5.3. Since then my “Utility Meter” helpers I use to track energy input and output are broken. Because of this also the Energy Dashboard shows completely wrong states. See attached screenshots.
The utility meters track the next import and export sensor which is a continues rising net meter. But since the update the helpers show also negative value drops which is just wrong for the raising sensor.
Is there a solution to solve this? Because this is basic functionality of home assistant and makes it unusable for me.
thx very much
Sensor “Zähler Energy Import” continuous raising
http://gofile.me/4MuEp/uGxiHUKJy
Helper “Utility Meter” on sensor drops after update ???
http://gofile.me/4MuEp/xCYScdGbC
Dashboard broken after update (Import shows wrong negative values, Export positive values)
no more screenshots possible
