Energy Dashboard appears to be carrying data over to the new day
So, I’ve got Home-Assistant installed in a docker container, I’m also using the HACS Integration for the AlphaESS Solar battery system. I can see all my sensors etc and get data from them and integrate them fine with the Energy Dashboard, however when I look at the data, it appears to be carrying over the totals for the day at Midnight which is then skewing my results in the rest of the graphs and daily totals, image for reference below.
Any help/advice greatly appreciated.
James
Try changing to “Use server time zone” under your profile settings (your initial on bottom left of toolbar).
Thanks, I’ve done that this morning, will see how things go over the next 24 hours.
I’ve also noticed that it may actually be affecting the sensors as they are also showing totals from yesterday as per this screenshot. Looking at the App from my battery provider, the values are obviously much less given its only 10am here.
Solar Sensor data
If it is that setting it should update immediately. There have been other causes as well - search the forums.
no change yet. Will go hunting in the forums and see what I can find.
