Grandor
(Thomas)
February 17, 2022, 5:47pm
1
Enmergy calculation of the three sensors
Grid Consumption - Shelly 3EM sensor
Production Solar Sensor Live, Daily & Total
Export ?? no Sensor available
Energy export is only when I produce more than I consume.
I’m still missing a sensor for the energy dashboard.
What is the best way to calculate this?
I currently have my solar sensor under “Production” & “Return”.
But that leaves the “Sefl-consumed” scale at 0% - logical in itself.
But I would like it to be 100% with this picture status, because I use the solar power myself.
Need help - thanks…
Grandor
(Thomas)
February 18, 2022, 10:42am
2
I built a solution that should work.
If the “solar” value is greater than the consumption, the value is displayed in the “export” sensor.
If the value is smaller - the “export” sensor indicates a “0.0”.
Sensor config:
sensors:
energy_shelly3em_total:
unit_of_measurement: "kWh"
value_template: "{{ states('sensor.shelly_a') | float | round (2) + states('sensor.sensor.shelly_b') | float | round (2) + states('sensor.sensor.shelly_c') | float | round (2)}}"
device_class: energy
sensors:
energy_export:
value_template: >-
{% if states('energy_shelly3em_total') | float(0) - states('sensor.energy_solar') | float(0) < 0 %}
{{(states ('sensor.energy_solar') | float(0) - states('energy_shelly3em_total') | float(0)) | round (3) }}
{% else %}
{{(states ('0.0') | float(0)) |round(3) }}
{% endif %}
Maybe it is helpful for you…
hello, thanks for your suggestion, i can see the sensor, but it’s not shown on the combobox “return to grid” on the energy dashboard config.
i did something wrong? thank you,
Grandor
(Thomas)
September 14, 2022, 11:55am
4
Here is my current config - hope it helps.
sensor.yaml
#Shelly 3EM
sensors:
energy_shelly3em_all:
friendly_name: "Stromverbrauch"
value_template: >
{{ [ states('sensor.shelly3em_channel_a_energy'),
states('sensor.shelly3em_channel_b_energy'),
states('sensor.shelly3em_channel_c_energy') ]
| map('float') | sum }}
availability_template: >-
states('sensor.shelly3em_channel_c_energy'),
] | map('is_number') | min
sensors:
energy_export_all:
friendly_name: "Grid_Export"
value_template: >
{{ [ states('sensor.shelly3em_channel_a_energy_returned'),
states('sensor.shelly3em_channel_b_energy_returned'),
states('sensor.shelly3em_channel_c_energy_returned') ]
states('sensor.shelly3em_channel_c_energy_returned'),
sensors:
power_3em_total:
friendly_name: "WATT_Live"
value_template: >
{{ [ states('sensor.shelly3em_channel_a_power'),
states('sensor.shelly3em_channel_b_power'),
states('sensor.shelly3em_channel_c_power') ]
states('sensor.shelly3em_channel_c_power'),
unit_of_measurement: "W"
device_class: power
