Hi folks.
Can you please help me understand how to show the grid and other sources consumption in 1 graph like so…
I’m only seeing consumption from grid in type: energy-usage-graph and no solar.
My setup:
Thanks in advance.
Hi folks.
My setup:
Thanks in advance.
You need an energy return to grid sensor.
Doing that shows the energy sent back to the grid from solar. I do not send energy back. I use grid tie inverter to use solar and only use grid when solar is not enough.
I would expect the positive kWh to show consumptions from grid and solar., It’s only showing grid.
Try creating a template sensor that always returns 0 kWh, add that as your grid return sensor.
template:
- sensor:
- name: Grid Return
device_class: energy
state_class: total
unit_of_measurement: kWh
state: "{{ 0 }}"
Adding this to your energy dashboard as your grid return should allow the calculations to display self consumed solar on the top graph.
