Energy Dashboard doesn't show data
Hi there!
I am running Home assistant in container (v2024.12.1). I have a e3dc system and unfortunately, in order to integrate it with home assistant, it has to be on the same subnet / vlan, in mycase the IoT vlan. So I have setup a home assistant instance on my vlan and integrated e3dc. All works well, energy dashboard shows all data, consumption, production etc.
In order to get the data into my main home assistant instance (running on k8s) also v2024.12.1) I use remote assistant and it used to work seamlessly. Since a while (don’t ask - should not use latest in prod, dooo) the energy dashboard in the main instance does not show any values or history anymore. The sensors are all listed in the “Source” section but all show 0 kW(h). However, if I click on the row in the “Source” section of the energy dashboard, I see the graph with all historical data, which match the vlan home assistant graph.
Seems like a very odd bug, maybe someone can help me out?
Best regards,
.c
Does the Energy Dashboard Configuration show any errors?
Na, no errors.
Logs showed “value violates unique constraint “statistics_pkey”” - I deleted all duplicates - now everything is working again.
