Energy Dashboard : Energy or power + decimals
Hi there,
I have mains GRID and solar panels … what entity should I be taking for the Energy dashboard ? Energy or Power ?
active_poser to total_active_energy ?
Also is there a way to see more digits (3 decimals) in the graph or have the values in watts ??
Many Thanks !!
For the Energy dashboard I would use the “total_active_energy” sensor.
If you want the values in watts, then multiply them by 1000.
Thank you … looks indeed like the “energy” has to be used, and not “Power” … but where Do I tell ti multiply by 1000 and have the Energy dashboard graph showing Wh iso kWh ?
See here I see 0.4 kWh that is very inaccurate … I would like to see at least 3 decimals or the unit in watts H :
