I have successfully connected the Hoymiles HM-800 inverter with MQTT. To be more precise, I connected the ahoy DTU, which I use to read the inverter, to HA.
Unfortunately, an error occurred when integrating the solar panel via the energy dashboard:
Entity not defined
Check the integration or your configuration that provides:
sensor.inverter_daily_yield
The sensor sends the correct data. (yield daily)
What can I do?
Thanks very much.
