has anyone an idea how to get the cost values presented in the energy dashboard?
i would really love to use these, instead of making template sensors and do the calculations another time for myself…
These calculations are not available as entities.
I used an SQL sensor to retrieve the costs and make them available as a sensor.
For example to get the costs of the daily energy in the previous month I could use:
sql:
- name: "Energie verbruikt door laadpaal in de vorige maand"
unique_id: {some unique UUID}
unit_of_measurement: "€"
device_class: monetary
query: >
SELECT
max(statistics.sum) - min(statistics.sum) AS sum
FROM
statistics
INNER JOIN statistics_meta ON
statistics.metadata_id = statistics_meta.id
WHERE
statistics_meta.statistic_id = 'sensor.electricity_meter_energy_consumption_tarif_1_cost'
AND start_ts >= unixepoch('now', 'start of month', '-1 month', 'utc')
AND start_ts <= unixepoch('now', 'start of month', 'utc')
column: "sum"
You can find the entity id to enter in the Developer/Statistics screen and search for the corresponding cost entity.
I checked with the value in the energy dashboard and it matches exactly.
Extract it from the database, hmmm. that’s smart!
Too bad, but i think they should be available.
maybe in the next version
Vote here:
good suggestion! let’s vote for that immediately
I modified the query to show last month and this month consumption. I’m no DEV/IT - just played with epoch for a bit. Not sure if it’s correct, but it works.
configuration.yaml
sql:
- name: "Energy Cost SQL - previous month"
unique_id: energy_cost_sql_prev
unit_of_measurement: "kWh"
device_class: energy
query: >
SELECT
FROM
statistics
WHERE
statistics_meta.statistic_id = 'sensor.myenergi_30cdw_charger_grid_import_today_2'
column: "sum"
- name: "Energy Cost SQL - this month"
unique_id: energy_cost_sql_this
query: >
SELECT
FROM
statistics
WHERE
AND start_ts >= unixepoch('now', 'start of month', 'utc')
AND start_ts <= unixepoch('now', 'start of month', '+1 month', 'utc')
column: "sum"
This exactly!
In the Developer Tools → Statistics I can find for my entities:
sensor.meter_total_energy_importa cost entity calledsensor.meter_total_energy_import_costsensor.meter_total_energy_exporta compensation entity calledsensor.meter_total_energy_export_compensation
These store daily values.
