Energy Dashboard: Keep History of obsolete Gas Utility Meter
recently I completely removed my Gas heating. So there will be no gas consumption anymore.
Is it possible to remove the Gas meter from the dashboard while still being able to view data in the past? I‘m not talking about completely deleting the entity. Just removing it from the dashboard from now on. Currently it just shows 0 consumption for any upcoming day. Would be nice to hide it.
Thanks in advance!
set ‘visible’ to ‘disabled’ in the entity/device settings?
Already tried that. Just setting it to ‚hidden‘ does not seem to have an effect in the dashboard. Disabling the entity just results in showing the entity without its display name. It shows its id instead.
oh ok I was thinking the default regular dashboard not the energy dash?
did you add the gas to the ‘sources’ or ‘individual devices’ ? you may need to go into the dash > energy configuration, and remove it.
that should remove it from the dashboard, but I don’t know if that will remove the history.
maybe do a backup before removing just in case.
Yes I’m talking about the energy dashboard.
I’m pretty sure it will remove the data as I already removed my water consumption in the past. I’m not able to access the data anymore.
And no, I didn’t add them as individual devices. This is only possible for power devices as far as I know
I didn’t think that the history would be removed until the whole device/integration was removed, but it would be great info to get it confirmed.
Maybe I will try it in a few days. I was hoping not to do any experiments :slightly_smiling_face:
