Energy Dashboard Not Aggregating Usage
I have my energy dashboard configured and displaying gas and electricity usage, apart from the Energy Distribution graphic which while it displays both gas and electric going into the home it is only showing the electric usage as the total. Any ideas how I can fix it?
How did you configure your gas consumption in kWh?
Will this Energy distribution created automatically or do you need to configure it manually?
I just added the gas and electric to the energy dashboard. Everything else works as expected just not the total figure. I’ve event deleted the dashboard and started it again but it didn’t make any difference.
Thanks, got it.
And I can confirm, that the gas consumption is not included in the total energy consumption.
Thanks NCO3, is that a bug in the interface do you think?
I am not quite sure, but I assume it will be addressed soon as I have seen some people mentioning this in other threads as well.
I won’t complain, because the energy dashboard is awesome.
(still wait for Water to be included as well :slight_smile:
Did this get resolved or fixed? I have the same issue and so far the gas consumption is not added to the total house use in my case either!
Hi there
I didn’t find a fix for this in the end unfortunately. I did raise it on github but it was closed as nobody responded.
Energy Dashboard Not Aggregating Usage · Issue #13838 · home-assistant/frontend (github.com)
